  • SN95 4.6L Mustang Tech
4.6 help needed
  • Thread starter Thread starter 68GEETEE
  • Start date Start date Jul 13, 2004
68GEETEE
5 Year Member
Nov 21, 2003
481
Texas, USA
Jul 13, 2004
  • Jul 13, 2004
I just bought a 98 Gt 5speed, stock motor. It cranks a very long time before finally starting. I found the air filter, throttle body and maf very dirty, so I cleaned them. The original plugs were worn out so I replaced them with new autolite platinum. The engine definitely runs smoother but it still cranks a long time before starting, what else should I look for?
T
tangerine
555
millen, ga
Jul 13, 2004
  • Jul 13, 2004
It could be a billion different things. It could possibly be your starter. I would take it to a mechanic so that they can diagnose.
Green4.6GT
Size Matters
2,910
Regina, Sask, Canada
Jul 13, 2004
  • Jul 13, 2004
my 96 did the EXACT same thing... i will be willing to bet that it is your fuel pump, i changed mine and its like a brand new car again
the problem was the pump was letting fuel leak partially back into the tank, so there wasnt enough fuel pressure during the initial moments of starting, so the car wouldnt fire, after a second the pressure would come up and everything would be better, also if i sustained a highish rpm for a long time, then the car would start to ping, because the motor was drawing a constant amount of fuel (highway cruising, 3000+ rpm or more) so it would slowly trickle out again... this also went away with the new pump..
hope this helps
68GEETEE
5 Year Member
Nov 21, 2003
481
Texas, USA
Jul 13, 2004
  • Jul 13, 2004
hope this helps
You may have a point. I have been listening to the pump activate when I turn the key on, but maybe its getting weak due to the mileage and age of the vehicle. I think I am gonna try changing the fuel filter first, I suspect it is the original, and if that doesnt work, I will take your advice and get a new pump. Thanks for the reply.
hotmustang331
2,967
Bastrop,TX
Jul 13, 2004
  • Jul 13, 2004
Here is a way to check it, hold the key in the ON position for 5 seconds, then crank it.If it still takes awhile, then its not you fuel pump and its one of the 999,999 other things LOL.
Green4.6GT
Size Matters
2,910
Jul 14, 2004
  • Jul 14, 2004
nope, mine still had trouble even if i left it, it was weird..
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Jul 14, 2004
  • Jul 14, 2004
i would change the fuel filter and then maybe try a injector cleaner. at school we have this thing that taps into the test valve on the injector rail and you run the motor off of that for 20 mins, and it actually does a good job of cleaning out injectors.
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Nov 2, 2026
manicmechanic007
  • Gulftown980x
  • Jul 29, 2026
squeak93
F
1986 mustang no start
  • foxyjamss221
  • Oct 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 13, 2025
foxyjamss221
F
