  • SN95 4.6L Mustang Tech
4.6 Internals
  • Thread starter Thread starter silversnake03
  • Start date Start date Dec 16, 2003
1 of 2 Next Last
silversnake03
43
  • Dec 16, 2003
Just out of curiosity, what's the most boost you've ever seen on a stock 4.6 bottom end? I want to know just how much power I can squeeze out of the factory internals!!!!!!!
stangman
2,690
10
69
in a 3 bed, 2 bath
Dec 17, 2003
  • Dec 17, 2003
well it depends on what bottom end we are talking about the old 4v, 2v, or a 03 cobra bottom end
tontot77
Do I look like a :taco: in this picture?
Apr 2, 2003
409
Dyer Indiana
Dec 17, 2003
  • Dec 17, 2003
careful, boost is not always what will take them out... I blew my piston #7 with a good tune and only 8psi... it can be just the power is too much... only so much tq/lbs...
silversnake03
43
  • Dec 17, 2003
I was referring to the 2v.
stangman
2,690
10
69
in a 3 bed, 2 bath
Dec 17, 2003
  • Dec 17, 2003
well from what i've seen on here & in person, 350-400 rwhp tends to be the limit. now there area ton of different circumstances that could affect that as well. such as a really good tuner, how easy you are on the car, etc...... But more than anything, detonation will kill the engine in a heartbeat. that's the kicker. hope it helps
Atlanta_GTer
866
I think the name gives it away
Dec 17, 2003
  • Dec 17, 2003
Its a hit or miss ballgame. There are guys running over 400 rwhp on the stock bottom end. How long will it last? A week, a month, a year? Boost is not the real killer, detonation is. However, even with a good tune, the stock internals will eventually crap out. Just up to you on taking your chances. I will say that more guys running the Steeda tune or the T&J Performance tune are making more and "safer" power.
Hell, I spun 2 rod bearings on 250 rwhp, so you don't need boost to waste an engine.
scheister
612
Indy
Dec 17, 2003
  • Dec 17, 2003
Yeah, I just started the fund for my built bottom end immediately after I finished installing the Novi 2000. I'm pretty much planning on it crapping out on me this next spring, but at least I'll have the money to go visit Tim in Atlanta. hehe
BTW, I saw almost 12 pounds of boost on the dyno, and not one sign of detonation.
Just keep some money set aside in case it decides to croak.
GreekStang85
485
  • Dec 17, 2003
thats why you forge your motor first and then boost
'96&'01Stang
798
Georgia
Dec 17, 2003
  • Dec 17, 2003
whats the fun in that
Dan_Soprano
7,410
54
129
Jacksonville, FL
Dec 17, 2003
#10
  • Dec 17, 2003
  • #10
OH CRAP!!! I hope my bottom end holds out once i put the KB on, cause I am going to be one BROKE mo-fo for awhile!!!!!!!!!
scheister
612
Indy
Dec 17, 2003
#11
  • Dec 17, 2003
  • #11
[QUOTE='96&'01Stang]whats the fun in that[/QUOTE]
EXACTLY!
hehe..
SmithAtlanta
1,111
Roswell, GA
Dec 17, 2003
#12
  • Dec 17, 2003
  • #12
You could be on the edge with 12 lbs but who knows for sure. I believe Tim(Cobra Killer) had his car around 450hp for nearly a year on the stock bottom end before he went crazy(and turned it into a drag racer).
I'm seeing close to 10 in this cold weather but I'm typically at 9 in the summer.
Heck, you may keep it at 12 for a year and still not need a new engine. I've bounced it off the rev limiter several times by accident and it still runs fine(wouldn't recommend doing that everyday). I don't know anyone that's blown up an engine due to the tune, yet....
MrMorden
754
Athens, GA
Dec 18, 2003
#13
  • Dec 18, 2003
  • #13
I am over 400rwhp with a tune by T&J, and I really don't get the feeling I'm living on borrowed time. Once my 42lb'ers and Pro-M MAF go in, and the restrictor comes out, I should see 11psi and ~430rwhp. If my motor goes tango uniform in the next 6 months I'm kinda screwed, but I really don't think it will happen. (fingers crossed)
SmithAtlanta
1,111
Roswell, GA
Dec 18, 2003
#14
  • Dec 18, 2003
  • #14
I think you'll get 430, easy. I was talking to Tim about the torque numbers on all the novi 2000's and he told me that it's due to the size of the charger. It really wants air. I bet your torque will jump up close to 40 ft-lbs when you step up the boost to 11lbs. Heck, your not even 1/2 way to the novi 2000's max at 11lbs!!!!
Screwed2V
1,255
Misery
Dec 18, 2003
#15
  • Dec 18, 2003
  • #15
My car had nitrous on it at 900 miles, a procharger at 1500 miles, and an s trim at 7500 miles. Power was 341 rwhp, 377 rwhp, and finally 437 rwhp with no issues at all.
There are more and more cars making well over 400 rwhp these days with the engines living but as stated above you never know when it'll go kaboom. Obviously a good tune is a must have but there comes a point when you can simply overpower the pencil rods in our cars.
9
98gt4me
32
Pennsylvania
Dec 18, 2003
#16
  • Dec 18, 2003
  • #16
my bone stock 98gt had a motor installed under warranty at 60k. The number 8 cylinder went and thru a rod. It blew a hole in the block. Two weeks after I got it back it started leaking coolant. Ford installed a new intake manifold. Needless to say, you never know how long its going to last.
scheister
612
Indy
Dec 18, 2003
#17
  • Dec 18, 2003
  • #17
hmm
'96&'01Stang
798
Georgia
Dec 18, 2003
#18
  • Dec 18, 2003
  • #18
that sucks
98GTfromGA
291
Memphis
Dec 18, 2003
#19
  • Dec 18, 2003
  • #19
snakbtn was running 20 psi through a stock longblock and over 600 rwhp for quite some time til his motor let go
the tune is very important
'96&'01Stang
798
Georgia
Dec 18, 2003
#20
  • Dec 18, 2003
  • #20
I guess it is just hit or miss
1 of 2 Next Last
W
I have some 4.6 questions.
  • whiskerz
  • Nov 14, 2025
SN95 4.6L Mustang Tech Nov 25, 2025
squeak93
Fox Good shop in Washington state or Oregon
  • keel
  • May 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 20, 2026
keel
Resolved Holley terminator integration into CCRM
  • BrandonMP
  • Feb 25, 2026
SN95 4.6L Mustang Tech Aug 23, 2026
fasterthangas
F
L
5.4 4v base ignition timing table help.
  • leoleo
  • Aug 16, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Aug 17, 2026
MustangBetts
M
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Aug 4, 2026
jake411
J
