8 86gtriceeater Member Aug 4, 2006 316 0 17 Whitewater, WI Oct 25, 2009 #1 Oct 25, 2009 #1 I swapped a 4 cylinder to a 5.0 got everything done, but now the car will not fire. I used a 302 from a lincoln so i used that firing order. I am getting gas to the motor and through the plugs, but it still will not turn over.
Mustang5L5 That is…until I whipped out my Bissell Mod Dude Feb 18, 2001 43,371 18,119 224 Massachusetts Oct 25, 2009 #2 Oct 25, 2009 #2 Confirm that the rotor points to #1 plug (front passenger side) when the piston as it TDC. Also, which Lincoln did you get the motor from? Town Car or Mark 7?
BK_CAULEY it's built for speed not longevity, woman Dec 26, 2006 0 10 49 Thomasville, ga Oct 25, 2009 #3 Oct 25, 2009 #3 did you also make sure the injectors are plugged up in the H.O. order? and when you bring it to TDC make sure its on the compression stroke. edit: is it not turning over or is it turnig over and not firing? you stated both.
tannerc91gt This last 25% is foreign territory at this point Founding Member Nov 29, 1999 4,392 2,967 234 Indiana Oct 25, 2009 #4 Oct 25, 2009 #4 this belongs in teh tech, just like the last thread you made, yesterday...
