I have been having a problem with my 85 GT headlights. While im driving down the road, my headlight will go off then come back on. do i have a bad ground? or is it something else?
Thanks
Thanks
Ny Mustang Guy said:check ur switch.. does it happen when u hit bumps.. or uneven road Etc.. or just out of nowwhere.. either the switch (I had to replace mine because of the part where u turn the knob for ur interiors had cracked in pieces lol).. bad ground.. loading.. Loose wire...or short?.... are you running anything off of it? If you think its the switch.. turn the switch on and wiggle it around to see if it happens
bluevenom867 said:I got a problem with our head lights,but its differant.
All four come on,but they do get brighter when you flick the high beams on.
Could this be the switch also?
I got a replacement,just havent got around to installing it.
