4 Wheel Disc Brakes - Power or Manual?
  • Thread starter Thread starter Ferf
  • Start date Start date Apr 20, 2010
F
Ferf
170
  • Apr 20, 2010
I am in the process of putting my '65 coupe back together. The car originally had manual drum brakes. However, I have upgraded to Wilwood disc brakes all the way around. Is it worth upgrading to power discs or do you feel that manual discs is the way to go?
If I go with power discs it seems that I have limited options on getting a power booster / master cylinder. Master Power Brakes has the following for just under $400 -
Master Power Brakes - FORD 7" POWER BOOSTER / MASTER CYLINDER (MANUAL TRANSMISSION)
Does anyone know if this setup would require me to alter my pedals in any way?
Or, Mustang Steve has this setup for around $430 -
BRAKES
All comments and opinions are appreciated!
rbohm
6,698
550
204
tucson,az
Apr 20, 2010
  • Apr 20, 2010
that depends on what pads you are using, and how strong your leg is. oh and what master cylinder you are using.
H
htwheelz67
444
mission viejo ca.
Apr 20, 2010
  • Apr 20, 2010
Power no question, why anyone would have manual brakes I havent a clue.
zm830101
116
warner robins, ga
Apr 20, 2010
  • Apr 20, 2010
+1 vote for mustang steve here. i loathe my cable clutch but the power brakes have been the cats pajamas since the day i installed. i only wish i had converted sooner! 4 wheel ssbc kit all around for me was useless until i upgraded with the mustang steve kit. shipping and communication was top notch as well.
tx65coupe
Apr 21, 2010
  • Apr 21, 2010
I have 4 wheel disc with Granada front and Versailles rear. I do not have a power booster. I am running a dual reservior master cylinder from CJ Pony that is for non power disc. I have to say that it works great. The pedal effort is not much and it stops very well. I'm happy with it.
2+2GT
3,333
10
79
Southeastern Pennsylvania
Apr 21, 2010
  • Apr 21, 2010
It's a very personal question. My 66 was my daily ride for over 20 years, with manual K/H factory discs. However, the booster you have illustrated is an excellent item, and if you wanted smooth, original-equipment-like boosted brake operation, there is no better choice.
brianj5600
1,964
Middle TN
Apr 21, 2010
  • Apr 21, 2010
Manual brakes are less forgiving on bore size on the master cylinder. I tried with the one I hsd on the car, one I had on the shelf and I finally bought one the right size. If the bore is too big you will never get the line pressure to make them work. Effort on mine is higher with out a booster, but it is not a high enough I want a booster.
Wicked65
490
NORCAL
Apr 21, 2010
  • Apr 21, 2010
I just put a strange manual master cylinder on my 65 with disc. When you go big cam or anything like that, a mastercylinder wont have the vacuum needed to run, along with space needed for the 351, didnt really seem like enough benifit to have power.
F
Ferf
170
  • Apr 21, 2010
Does the MPB power booster and master cylinder require modification to the brake pedal? Why go with one power brake setup (MPB and MustangSteve) over the other?
tx65coupe
Apr 22, 2010
#10
  • Apr 22, 2010
  • #10
I had to get an adjustable pushrod for my MC which is made by Master Power Brakes. I got the SSBC one, if I remember right.
66Runt
680
Apr 22, 2010
#11
  • Apr 22, 2010
  • #11
Good question Ferf.
No you will not have to modify the pedal.
As to choice between kits, I'd look at quality of components, and parts availability, from a local supplier. Can you get the master cylinder or master cylinder rebuild kit from Napa, or do you have to go back to the company you bought the assembly from.
Also bore (as mentioned above) and bias is critical.
Something that has not yet been mentioned, and is pretty critical, is bias of the master cylinder. Most disc/drum, and drum/drum master cylinders are biased 65% front 35% rear. Most Disc/Disc systems require a 60% front, 40%rear bias. If you do not have the correct bias, the rear brakes will not function correctly, in concert with the front brakes.
Before proceeding, I'd highly recommend a call to Wilwood, and find out what bias the system you installed is designed for. Then figure out which power master assembly fits your brake system correctly.
Even with an adjustable proportioning valve, if the bias is incorrect, braking performance will suffer. And if too far off, will be dangerous.
Good luck,
mtaqua
345
#12
  • Apr 22, 2010
  • #12
As far as a large cam and not enough vac, I am going to try an electric pump. SSBC said there's was designed to run without vacuum from the motor. Some complain it is loud, but with a large cam (and all that goes along with it); I doubt I'll be able to hear it with the engine running. Also, should give me power brakes with the engine off; which I thought would be a great safety feature. I bought a mustang steve kit.
Wildbill3
57
#13
  • Apr 22, 2010
  • #13
Interesting Ferf what kit did you use from Willwood did that come with hubs and all for the drum spindals?
65FBE2
283
Minnasnowta
Apr 24, 2010
#14
  • Apr 24, 2010
  • #14
1+ for Mustang Steve set up. It fits with the large 10" booster vs the small factory unit. Need to drill one new hole in firewall and slightly inlarge the pushrod hole but all this is behind the booster and does not show
jerry S
1,365
52.22N 5.12E
Apr 25, 2010
#15
  • Apr 25, 2010
  • #15
I went from manual to power brakes using a MPB conversion kit and yes, I had to use a new brake pedal arm. It requires relocating the pedal arm to a different pivot point. I got the electric vacuum pump only it simply does not work. It turns on but never turns off.
W
New here, 1967 getting an efi 348 stroker.
  • Weeman348
  • Mar 27, 2026
1965 - 1973 Classic Mustangs -General/Talk- Mar 27, 2026
Weeman348
W
68 manual disc/drum master cylinder
  • Butchd88
  • May 27, 2026
1965 - 1973 Classic Mustangs -General/Talk- May 27, 2026
Butchd88
Manual disc brakes
  • Butchd88
  • Feb 28, 2026
zookeeper
O
1967 Manual Drum Brakes , replaced the master cylinder and the brake light switch but the brakes lights stay on.
  • OldNSloww
  • Jul 14, 2025
Classic Mustang Specific Tech Jul 16, 2025
horse sence
G
Auto City Classics 67-70 Mustang disc brake kit question/s
  • GOvert
  • Jun 30, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 30, 2026
GOvert
G
