4100: bog / hesitiation when stomped
GT1966
69
Maine
OK, I've got a 4100 from Pony Carbs 1.08 bore on a 1985 302 block. .030 over, balanced and decked for ~ 9.3 :1 compr. ratio. The cam is flat tap hydraulic 216 Adv. Duration @ .050... (pretty mild / decent idle) and World Products Windsor Jr. heads, and Edel. Performer RPM intake.... when I give it full throttle, it nearly sends me first through the windshield, then it snaps me back a half second later when the motor gets its act together and it pulls awesome! I'm wondering if this is the carb's power valve / accelerator pump issue or is this a timing / spark curve issue? If I feed the fuel to it rather than stomp it, it works great through a solid power band. Per Jon @ Pony, I've got the timing running max vacuum, so what's my next move? I want to install an MSD distributor (presently running Pertronix in an orig. 289 distributor), but I want to close one chapter before introducing another variable. Thoughts?
GT1966 :shrug:
Well DHearne, you never steered me wrong before! :hail2: I don't know the degree advance number; I basically tuned for maximum vacuum at idle per Pony's instructions. I read where having had a back-fire through the carb could damage the power valve.... had that happen a year or two ago when I had a firing order "misunderstanding" with my new (early firing order) camshaft! My gut tells me it is not the distributor curve, since the bog is immediate when you punch the accelerator. ....and if the condition was too lean, it would pop back through the carb upon stomping it? I guess if it was spark timing, the reason why it runs fine as I feed the throttle is that it gradually advances the timing, rather than not having enough advance at low rev, wide-open stomp? I guess I'll crank-in some more advance and see if it helps.... however, seems more advance makes the engine difficult to crank for cold starts.
Cliff
i always set the timing to 10 degrees with a light to start, then adjust it within a few degrees by ear until the harmonics are in tune (it's a musician thing) then play around with setting the carb using a vacuum gauge, this is how i've always gotten the best performance out of my cars. it will generally take me all day to get everything where i want it, then i check the timing with a light again just to see where it ended up, and without fail it ends between 10 and 16 degrees initial depending on how the advance curve in the distributor is set
