Engine 5.0 block interchangeability
  • Thread starter Thread starter MemnochtheDevil
  • Start date Start date Aug 17, 2024
M
MemnochtheDevil
  • Aug 17, 2024
Hi guys! Simple question: Can a 5.0 roller bare block be substituted for a flat tappet block?
Admin Dude
Jan 4, 1985
43,535
21,705
234
Box behind Walmart
Aug 17, 2024
  • Aug 17, 2024
Yes.
Depending on application, you might have to change oil pan and accessories/drive. The distributor needs to be an 85 style for carb or aftermarket with a steel drive gear.
Reactions: General karthief, limp and 89ripper
AeroCoupe
6,207
4,309
183
Claremore, OK
Aug 17, 2024
  • Aug 17, 2024
Just for clarity sake are you wanting to use a roller block where a flat tapper block was and reuse everything from the flat tapper block?
limp
wrap a little cheese around it and its a done
5 Year Member
Oct 4, 2020
5,520
2,945
173
Florida
Aug 17, 2024
  • Aug 17, 2024
If your wondering about items not working with from a flat tappet block to a roller block. I installed an Explorer roller block gt40 P head engine in my 83... Everything bolted right up,,, Accessory brackets, Accessories, 4 barrel Intake, pan...
The only thing I can think of that did not, are the stock exhaust manifolds and the air pipe that comes off the back of the heads to the cat......
You could use different heads than I and probably get those items to work also....
AeroCoupe
6,207
4,309
183
Claremore, OK
Aug 17, 2024
  • Aug 17, 2024
The flat tappet cam will go right in the roller block. You will need different lifters and different push rods. Other than that it should all bolt right up. The spider and dog bones (if they came with the block) are not needed.
C
Flat tappet to roller lifters--older block
  • chazmanaz
  • Jan 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 27, 2026
Fox Block Decode
  • PonyGTrider
  • Jun 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
PonyGTrider
R
Engine Block Identification
  • Ranger302
  • Feb 22, 2025
Fox 5.0 Mustang Tech Feb 22, 2025
AeroCoupe
Engine Forged flat top pistons from 5.0 fit a 351 build?
  • PonyGTrider
  • May 22, 2025
2K
Fox 5.0 Mustang Tech Feb 1, 2026
PonyGTrider
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
