5.0 Cams
  • Thread starter Thread starter FordGuy88
  • Start date Start date Jun 4, 2005
F
FordGuy88
241
Park Ridge, IL
Jun 4, 2005
  • Jun 4, 2005
I have a 88 Mustang 5.0. It is a It isnt MAF. I was wondering if I would be able to put a real mild cam in the car. Would it still run ok? Because I know when you put a big cam in a Speed Dencity car the computers **** out. If I am able to can you tell me what kind of cam or the specs on it.
Thanks,
Dave
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Jun 4, 2005
  • Jun 4, 2005
What other mods do you have Dave? If the car is stock, you'll get much more bang for the buck with other mods before you mess with the cam. There are MANY people out there running 12's with the stock cam.
I'd look at exhaust, intake manifold and possibly different heads before I messed with the camshaft - especially in an SD car.
F
FordGuy88
241
Park Ridge, IL
Jun 4, 2005
  • Jun 4, 2005
The car is for the most part stock. I just have exhaust on it. But I was just wondering if it is possible.
C
crunchie12268
599
Manhattan, KS
Jun 4, 2005
  • Jun 4, 2005
get some gears and short throw, good exhaust, intake.... but I would think putting in a cam that wouldn't effect the SD wouldn't be worth it anyways. Try putting on some 1.7 roller rockers and see what happens, that will give you more lift.
C
crunchie12268
599
Manhattan, KS
Jun 4, 2005
  • Jun 4, 2005
you can put anything on a SD car, cam, heads, supercharger etc. if you get the thing tuned and a chip burned.
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
Jun 4, 2005
  • Jun 4, 2005
As Mr Yount stated..throwing in a cam with all other components stock is just not the route to go. The stock cam is really quite a good runner...your true bottle neck items are the heads/intake. A "small cam" will net you next to zero gain without other components..maybe 10HP..trust me that's alot of work for 10HP when there are so many alternative mods available to you. My car DID not enjoy being moded and turned into quite a cranky little bastard in regards to idle quality when I began modifying my little one. I had to convert to mass air so I could use the components I wanted to use. Anyhow...VERY few places are left that can dyno tune an SD car..and the minute you change anything..the chip would be inaccurate. AS stated above get the gears, shifter, subframe connectors..then maybe a head/intake swap..then think about the cam shaft.
F
FordGuy88
241
Park Ridge, IL
Jun 4, 2005
  • Jun 4, 2005
My car is auto so I wouldnt need a short throw. But any ways I am building a new motor. I was thinking about honing it, and then keeping the stock crank. Then forged pistons and rods. That is why I figured on putting a new cam in it considering I had the motor out at the time. But Thanks guys. If any one else has anything to add feel free.
Thanks,
Dave
z9_87
332
Urbana, IL
Jun 4, 2005
  • Jun 4, 2005
if you're building a new motor go mass air and be done with worring about what you can do.
_jb_
808
Michigan, Berrien County
Jun 4, 2005
  • Jun 4, 2005
Junk yard. Checkout the tech here at Stangnet for the good writeup about going to MAF. I'll be going that route myself soon.
J
Engine Tuning...?
  • justadude07
  • May 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
Engine Hiccup at full throttle
  • keel
  • Jun 2, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
keel
Fox Good shop in Washington state or Oregon
  • keel
  • May 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 20, 2026
keel
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Thursday at 6:08 PM
Fox 5.0 Mustang Tech Friday at 1:19 PM
General karthief
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
