5.0 EFI swappers...
  • Thread starter Thread starter 66 BLAKE 96
  • Start date Start date Feb 12, 2004
66 BLAKE 96
Native Texican
4,810
Cowtown
Feb 12, 2004
  • Feb 12, 2004
I'd like to get together a comprehensive list of what is actually necessary to do the swap. By that, I mean what is actually needed, not "what can you add on to the project to make it cost an extra $1,000".
Anyone who has spent any time on the vendor sites such as:
http://www.windsor-fox.com/ will recognize the multitude of extra stuff that no one ever mentions when discussing how they did their swap. For instance, HEGO relay $40, smog pump idler pulley $97, Fuel Pump Bracket $291, etc...
Whatcha think?
LMan
1,246
Mom's basement
Feb 12, 2004
  • Feb 12, 2004
I think the Mustangs Plus EFI rendition is about as cheap as one can get, at least Ive never read anything cheaper. They dont include pricing in that article but with the BIG ASSUMPTION that you can get around buying the "Ron Morris Wiring Harness" for ~$800.00 (cough), and can solder a return line, thats prob about $500 all told, if you use good used injectors, etc. Your biggest expense would be the fuel pump, inertia switch, and O2 sensors.
But Im not a EFI guru so I dont know directly.
68converted
772
Colorado
Feb 12, 2004
  • Feb 12, 2004
Whatcha think?
Here is what I have done so far and the list for the swap. I also am adding the AOD.
1. 91 GT- 5.0L motor complete w/ accessories, computer and ALL harnesses, and AOD. (67K miles on it for $1000 - I got lucky)
2. Used radiator w/ stagard in/out (86 mustang $40)
3. Fuse block and engine compartment relay block (89 Mark 8 $15)
4. 92 Taurus electric fan ($20)
5. TFI coil and solenoid (96 Lightning $ 10)
6. HD trans cooler (free)
7. 70 Mustang cable style gas pedal ($20-got ripped of by local Must. shop)
8. Aerostar Aluminum driveshaft (90 2wd $20 + $40 to shorten)
9. Electric fuel pump from BMW 7 series (almost brand new $15)
10. Flex fuel lines for EFI (too much $)- Using drain plug hole with AN6 90 for the return line
11. GM Truck fuel filter and found two brackets one for filter and one for pump ($15 for new filter and used brackets)
12. Headman headers (New)-Thanks Fostang
13. 2 1/2 exhaust with ORX pipe and 50's Flowmasters (on order $300 installed)
14. O2 Sensors new from Ford Dealer ($40 too much), welding in a nut to fit sensor
15. Deleted pump and A/C and will use shorter belt. No pullies.
16. Just got a 3G alternator (from a wrecked 2001 Crown Vic $30)
17. Fuel pump relay and inertia switch from (91 Mustang $10)
18. Will need new radiator hoses, vacume lines, various screws, etc. ($40)
19. Winsor-Fox shock tower brace (ordering in two weeks)
20. Winsor-Fox cross member (just got it)
21. Fabricated/welded a drivers side battery punch-out like original on the passenger side ($5 for the sheet metal)
22. Using a 302 pan and dipstick (new $50)
23. New gas tank, the old one has holes ($120)
24. Adjustable fuel pressure regulator. Not needed but free.
25. New '68 302 motor mounts ($30)
26. Cold air intake and K&N $50 used(could have used the 91 box, but low volume)
27. 4 cases of beers and a few bottles of the good stuff. (Friend's work fee $300)
28. I sure I will find more before I am done in April. (???? $$$)
29. And then there is the stuff to keep it on the road and look good parts, FULL suspension upgrade, 17x8 AC III's, Cobra Automotive R model front end, LeCarra Steering wheel, 91 GT seats, Auto Meter gauges, Granada Disc Brake swap, 67 Shelby hood, NEW PAINT!!!!!
30. Two gallons of Heavy Duty patience.
66 BLAKE 96
Native Texican
4,810
Cowtown
Feb 12, 2004
  • Feb 12, 2004
Awesome!
That is exactly the kind of info I'm looking for. Not only have you listed the things you need for the swap, but it is readily apparent what it is that you don't need. Thank you so much!
F
Fostang
1,400
Stockton, Ca
Feb 12, 2004
  • Feb 12, 2004
Where do I buy number 30 at?
P
PCH_Cruiser
69
Palmdale, CA
Feb 13, 2004
  • Feb 13, 2004
I probably needed 3 gallons of #30. 68conv. has quite a list. Way better than I can do. His list is a great example of why you should try to get as much as possible off a donor if thats the route you go. Gas pedal, alternator, sensors, anything you can grab. Depending on how worn the engine is, most people will want to add tune up stuff (sparkplugs, cap, rotor, plug wires, etc).
68converted
772
Colorado
Feb 13, 2004
  • Feb 13, 2004
I bought mine at the local Packy. That's the beer store for those not of East coast heritage.
68converted
772
Colorado
Feb 13, 2004
  • Feb 13, 2004
One last thing I just discovered. I was messing around with the valve covers in prep to take the cam out and the nuts were loose. I had not planned on doing anything until I got the engine in but... When I pulled the covers off, Loe and behold, roller rockers. FMS Blue ones! 1.6 I think? Hope that translates into an aftermarket cam as well. I will keep you posted.
I also forgot to add #31 Trans cooler lines (not yet purchased, ?$)
Håkan
168
Enköping, Sweden
Feb 13, 2004
  • Feb 13, 2004
Here´s when it´s needed:
D
Any info on Dunne Rite harness. 5.0 efi conversion 68 mustang.
  • Dan94GT
  • Aug 27, 2020
2K
1965 - 1973 Classic Mustangs -General/Talk- Sep 14, 2020
Dan94GT
D
J
Engine 90 LX 5.0 won't keep running, dies at idle
  • Jaybal80
  • Sep 17, 2019
Fox 5.0 Mustang Tech Sep 17, 2019
Jaybal80
J
M
5.0 beginner.
  • MustangJerry8680
  • Apr 17, 2013
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 19, 2013
Shakerhood
  • Locked
SOLD 1989 Lx 5.0 Hatchback F/s - Near Salisbury, Md - Price Dropped
  • UMDSmith
  • Nov 17, 2013
25K
Fox Body Mustangs For Sale (1979-93) May 14, 2014
M90 root blower how to info
  • 1987LXragtop
  • Jan 7, 2011
  • SN95 V6 Mustang Tech
8K
SN95 V6 Mustang Tech Jan 7, 2011
1987LXragtop
