66 BLAKE 96 said:
I'd like to get together a comprehensive list of what is actually
necessary to do the swap. By that, I mean what is actually needed, not "what can you add on to the project to make it cost an extra $1,000".
Anyone who has spent any time on the vendor sites such as:
http://www.windsor-fox.com/ will recognize the multitude of extra stuff that no one ever mentions when discussing how they did their swap. For instance, HEGO relay $40, smog pump idler pulley $97, Fuel Pump Bracket $291, etc...
Whatcha think?
Here is what I have done so far and the list for the swap. I also am adding the AOD.
1. 91 GT- 5.0L motor complete w/ accessories, computer and ALL harnesses, and AOD. (67K miles on it for $1000 - I got lucky)
2. Used radiator w/ stagard in/out (86 mustang $40)
3. Fuse block and engine compartment relay block (89 Mark 8 $15)
4. 92 Taurus electric fan ($20)
5. TFI coil and solenoid (96 Lightning $ 10)
6. HD trans cooler (free)
7. 70 Mustang cable style gas pedal ($20-got ripped of by local Must. shop)
8. Aerostar Aluminum driveshaft (90 2wd $20 + $40 to shorten)
9. Electric fuel pump from BMW 7 series (almost brand new $15)
10. Flex fuel lines for EFI (too much $)- Using drain plug hole with AN6 90 for the return line
11. GM Truck fuel filter and found two brackets one for filter and one for pump ($15 for new filter and used brackets)
12. Headman headers (New)-Thanks Fostang
13. 2 1/2 exhaust with ORX pipe and 50's Flowmasters (on order $300 installed)
14. O2 Sensors new from Ford Dealer ($40 too much), welding in a nut to fit sensor
15. Deleted pump and A/C and will use shorter belt. No pullies.
16. Just got a 3G alternator (from a wrecked 2001 Crown Vic $30)
17. Fuel pump relay and inertia switch from (91 Mustang $10)
18. Will need new radiator hoses, vacume lines, various screws, etc. ($40)
19. Winsor-Fox shock tower brace (ordering in two weeks)
20. Winsor-Fox cross member (just got it)
21. Fabricated/welded a drivers side battery punch-out like original on the passenger side ($5 for the sheet metal)
22. Using a 302 pan and dipstick (new $50)
23. New gas tank, the old one has holes ($120)
24. Adjustable fuel pressure regulator. Not needed but free.
25. New '68 302 motor mounts ($30)
26. Cold air intake and K&N $50 used(could have used the 91 box, but low volume)
27. 4 cases of beers and a few bottles of the good stuff. (Friend's work fee $300)
28. I sure I will find more before I am done in April. (???? $$$)
29. And then there is the stuff to keep it on the road and look good parts, FULL suspension upgrade, 17x8 AC III's, Cobra Automotive R model front end, LeCarra Steering wheel, 91 GT seats, Auto Meter gauges, Granada Disc Brake swap, 67 Shelby hood, NEW PAINT!!!!!
30. Two gallons of Heavy Duty patience.
