5.0 fuel pump location
  • Thread starter Thread starter shoguun
  • Start date Start date Aug 12, 2009
shoguun
184
  • Aug 12, 2009
i was just wonder for those who put a newer model engine in there old style mustang, where you put the fuel pump. if i remember correctly is suppose in the fuel tank on newer model cars. also do i have to put in a new fuel line if i convert a I6 to a V8
P
pyroman
480
Ennis, Texas
Aug 12, 2009
  • Aug 12, 2009
From your post I'm assuming you're using the electric pump. Are you going to run EFI or carb? I've got a late model 5.0 in my car and I'm running an early model 289 timing cover with a mechanical pump. But yes, generally the fuel pump with be in or near the tank. If I were you I'd go ahead and replace the fuel line anyway whether you need to or not.
shoguun
184
  • Aug 12, 2009
i have no pump yet. i was wondering where it goes or if i do use electric does someone what to post a pic of theirs. i figured it would be on the timing case
speed1972
891
Denver, CO - Buckley AFB
Aug 12, 2009
  • Aug 12, 2009
shogun,
it depends whether you are running carb or efi as to the style pump you are running. Mechanical pumps are going to give you about 6-8 psi. Most aftermarket electric pumps mounted externally run the same 6-8 psi and both of these work great for a carb set up. If you are going efi, those systems require around 40psi which is the "in tank" style found in fox body stang...
What are your plans for this project?
LB
shoguun
184
  • Aug 13, 2009
carb probably electric pump
speed1972
891
Aug 13, 2009
  • Aug 13, 2009
With a carb, I would suggest running an electric pump. Best placement is at the rear of the car mounted on the frame rail close to the tank. Electric pumps are much more efficient and will last longer pushing fuel instead of trying to pull the fuel. As far as the timing cover goes, use a block plate to cover the hole in the timing cover unless you are using a newer style (efi) cover then there will be no hole.
LB
shoguun
184
  • Aug 13, 2009
Can you recommend a good one
speed1972
891
Aug 14, 2009
  • Aug 14, 2009
It has been quite a while since I put one in so I don't know what's good/great nowadays. Anyone else have good info on this?
LB
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
L
2003 mustang v6 3.8 fuel issue
  • lacole1
  • Jul 20, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 26, 2026
apple99Mustangdude
A
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
Fox won't crank over and fuel pump won't kick on.
  • djj62478
  • Jun 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
General karthief
