5.0 Has trouble starting...
irwinner
The car in question is an 88 gt, the car has been sitting for some time with fuel stabilizer in it. Well we got the engine back together and tried to start the car it turns over quickly then seems to bog down then speeds up then bogs down again repeatedly and never starts, we have spark and fuel. Bad starter maybe? Or bad fuel? :(
Well the engine hasn't started for 1 year (took that long to get painted :mad: ) I think i'm going to get the gas tank cleaned out with a new fuel filter like you said since the gas might be bad. Intake gaskets shouldn't be leaking since they are new and I just installed them after a cam swap. But ill check that out too. Ill change the fuel filter tommorow to see if that helps out. Thanks for your suggestions. :nice:
yeah after a year of sitting any debri,dirt, would have alot of time to settle.I dont think the gas will be bad,especially if there was stablizer in it..The fuel filter mite be your ticket :nice:
If you press the gas pedal to the floor while (AND ONLY WHILE) cranking, it cuts the injectors. If you are fouling plugs or have a cranking fuel issue, doing this can help.
Good luck.
