5.0 MAP sensor
  • Thread starter Thread starter onefasthatch89
  • Start date Start date Jan 1, 2006
O
onefasthatch89
  • Jan 1, 2006
I got a check Engine light today it stays on all the time, i pulled the code it gave me a code 22.
i looked it up and it says that it has something to do with mAP pressure.
Where is the mAP sensor located on my 89LX 5.0.??
thanks guys
HISSIN50
34
129
Jan 1, 2006
  • Jan 1, 2006
Your 89 should not have a MAP sensor. It has a BAP sensor instead (MAF cars dont have MAP sensors).
Good luck.
RMODEL65
313
brunswick ga
Jan 1, 2006
  • Jan 1, 2006
on the firewall its a little black box!
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jan 1, 2006
  • Jan 1, 2006
Code 22 MAP (vacuum) or BARO signal out of range. The MAP or BARO sensor is pretty much the same sensor for both Mass Air & Speed Density cars. The main difference is where it is connected. Mass Air cars vent it to the atmosphere, while Speed Density cars connect it to the intake manifold vacuum. Its purpose is to help set a baseline for the air/fuel mixture by sensing changes in barometric pressure. The MAP or BAP sensor puts out a 5 volt square wave that changes frequency with variations in atmospheric pressure. The base is 154 HZ at 29.92" of mercury - dry sunny day at sea level, about 68-72 degrees. You need an oscilloscope or frequency meter to measure it.
Baro or MAP test using frequency meter - run the test key on engine off. The noise from the ignition system will likely upset the frequency meter. I used a 10 x oscilloscope probe connected from the frequency meter to the MAP/BAP to reduce the jitter in the meter's readout.
If it is defective, your air/fuel ratio will be off and the car’s performance & emissions will suffer
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Jan 1, 2006
  • Jan 1, 2006
Your 89 does not have a MAP sensor like JT said. Code 22 in an 89 would mean the BAP sensor is out of self test range. That code carried over from 88 to the 89, and could refer to either sensor, depending on the model year.
C
Electrical Under dash wiring
  • ChicagoMustang
  • Apr 17, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
A
A/F ratio gauge install questions.
  • AngryH58
  • Sep 24, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 22, 2026
Engine Keeping O2 sensors lit with long tube headers
  • keel
  • Jul 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
H
97 cobra maf sensor help
  • Hopper1979
  • Oct 16, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
CAMTWO1070
H
Engine 1987 5.0 HO vacuum hose locations
  • harryhaber
  • Jun 20, 2025
Fox 5.0 Mustang Tech Jun 21, 2025
limp
