5.0 Question
  • Thread starter Thread starter Allout_50
  • Start date Start date Jul 20, 2008
A
Allout_50
  • Jul 20, 2008
Well where do i start i'm just getting into the mustang world and need some help and or tips. 88 stang convertible V8 5.0 H.0. Car was given to me dont know to much of the history but it was a motor replacement cause the other went out. Before i started the car i went and bought a new radiator, electric fan, bosch plat 2spark plugs, new wires, cap and rotor,fuel filter and fuel pump, thermostst, and change of oil and filter, along with a new battery. Well i go to start the car it has a rough idle but it only firing on the 1,2,5. Theres spark going to all cylinders. The way i know this is because if you get a test light and stick through the distrubtor cap on the cylinder of choice the engine dies down, and if it doesnt then you have a problem on that cylinder. what could be the cause of this firing only 1,2,5 i figure it fuel related but dont know.
I also did a compression test and all numbers were good
dcurtis
688
Jul 20, 2008
  • Jul 20, 2008
get a code reader and pull the codes, after you get the codes pulled stomp the throttle and it will test each injector for you.
LiquidGT
368
Near STL hell
Jul 21, 2008
  • Jul 21, 2008
5.0's hate platinum plugs, especially Bosch, get some regular copper Motorcraft plugs.
You dont need a code reader for our cars, just a jumper wire or a test light will do fine. The check engine light doesnt have to be on for trouble codes to be present. There are plenty of diagrams on this site that tells you how pull the codes, jrichter might chime in with one of his many "how to's".
Fast63
717
  • Jul 21, 2008
I'm a little confused, are you saying it is only running on 3 cylinders, numbers 1, 2, and 5? Cause that's not possible.
HISSIN50
34
129
Jul 21, 2008
  • Jul 21, 2008
I agree that the cylinder misfire situation needs further work. It's probably running on more like 6 cylinders if it even idles worth a poo (That's not to say that those cylinders are all running at 100%).
As noted, the cylinder balance test is the way to figure out which cylinders are not contributing properly (if you can allow the car to run long enough to do this. It sounds like you can).
Alternatively, an inductive timing light on each plug wire can kinda give a clue about the spark for a given cylinder. A noid light can help one see the quality of the signal to the injectors (they receive constant key-on 12 volts and the EEC modulates ground to each one).
Be very sure your firing order is correct.
And while I doubt the plugs are the only issue, when dealing with something like this, I would get some copper plugs (as was suggested). I've seen the difference in idle quality with plats vs coppers on 5.0's and it was noteworthy in said instance. Copper conducts better.
What are you current plug gaps?
You might want to run a slightly closed gap with the fresh plugs (something like 0.045" for now).
Good luck.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 21, 2008
  • Jul 21, 2008
Cylinder balance test:
Warm the car's engine up to normal operating temperature. Use a
jumper wire or paper clip to put the computer into test mode. Start
the engine and let it go through the normal diagnostic tests, then
quickly press the throttle to the floor. The engine RPM should exceed
2500 RPM's for a brief second. The engine RPM's will increase to about
1450-1600 RPM and hold steady. The engine will shut off power to each
injector, one at a time. When it has sequenced through all 8 injectors,
it will flash 9 for everything OK, or the number of the failing cylinder
such as 2 for cylinder #2. Quickly pressing the throttle again up to
2500 RPM’s will cause the test to re-run with smaller qualifying figures.
Do it a third time, and if the same cylinder shows up, the cylinder is
weak and isn’t putting out power like it should. See the Chilton’s Shop
manual for the complete test procedure
Here's the link to dump the computer codes with only a jumper wire
or paper clip and the check engine light, or test light or voltmeter.
I’ve used it for years, and it works great.
See Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
Do a compression test on all the cylinders.
Take special note of any cylinder that shows up as weak in the cylinder
balance test. Low compression on one of these cylinders rules out the
injectors as being the most likely cause of the problem. Look at cylinders
that fail the cylinder balance test but have good compression. These
cylinders either have a bad injector, bad spark plug or spark plug wire.
Move the wire and then the spark plug to another cylinder and run the
cylinder balance test again. If it follows the moved wire or spark plug,
you have found the problem. If the same cylinder fails the test again,
the injector is bad. If different cylinders fail the cylinder balance test,
you have ignition problems or wiring problems in the 10 pin black &
white electrical connectors located by the EGR.
How to do a compression test:
Only use a compression tester with a screw in adapter for the spark
plug hole. The other type leaks too much to get an accurate reading.
Your local auto parts store may have a compression tester to rent.
If you do mechanic work on your own car on a regular basis, it would
be a good tool to add to your collection.
With the engine warmed up, remove all spark plugs and prop the
throttle wide open, crank the engine until it the gage reading stops
increasing. On a cold engine, it will be hard to tell what's good &
what's not. Some of the recent posts have numbers ranging from
140-170 psi. If the compression is low, squirt some oil in the cylinder
and do it again – if it comes up, the rings are worn. There should be
no more than 10% difference between cylinders. Use a blow down
leak test (puts compressed air inside cylinders) on cylinders that
have more than 10% difference.
See the link to my site for details on how to build your own blow
down type compression tester.
The HO firing order is 1-3-7-2-6-5-4-8.
Non HO firing order is 1-5-4-2-6-3-7-8
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Jul 21, 2008
  • Jul 21, 2008
Check your firing order.
Also toss the Bosch +2's in the trash. They hurt more than help. Stock motorcraft copper plugs are what these 5.0's love
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
M
Electrical 93 5.0 No Injector Pulse
  • machinermac
  • Jul 26, 2026
Fox 5.0 Mustang Tech Aug 1, 2026
Willybill32
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
