5.0 vs. 5.0 HO
  • Thread starter Thread starter blackLX_92
  • Start date Start date Sep 26, 2007
blackLX_92
  • Sep 26, 2007
whats the diffrence in the 5.0 and the 5.0 HO i mean i know the fireing order is diffrent but other than that are they basically the same
and i have a 92 LX that has the 5.0HO pulled out and a carbed reg. 5.0 in it
the reg. 5.0 has been shaved and a roller valve train stock cam i have a E303 but dont know if itll work in it cuz of the diffrent fireing order...i might be able to get my hands on a HO but im gunna switch that HO to a carb...should i through out the reg. 5.0 and get the HO or is it worth it?? this is my first stang and i want it to screem ....so far it has 4.10 gears,tubeular upper and lower contol arms, short through shifter, holley electric fuel pump and regulator, MSD ignition, accel coil, ford racing 9mm plug wires, edlebrock performer 289 intake, full ford racing roller valve train, and a holley 600 cfm carb but im getting my new edlebrock this weekend!!!!!
87foxstang
Cromwell, CT
Sep 26, 2007
  • Sep 26, 2007
im not sure about all the differences in the two but i know the intake faces left lol. I would go with the HO
samickguy15
404
Delavan, IL
Sep 26, 2007
  • Sep 26, 2007
If the 5.0 has been converted to roller then it is basically an HO.
When you swap an HO style cam for a standard cam or vice-versa all you have to do it switch your plug wires around. So that's not a big deal.
blackLX_92
  • Sep 26, 2007
what about the crank ... what you said i dont think would work id have to get an HO crank right?
Fast63
717
  • Sep 26, 2007
All 302 cranks are the same as far as that goes. When the firing order was changed, it just swapped cylinders that both came to TDC at the same time. Observe:
HO firing order: 13726548
old firing oder: 15426378
1, 2, 6 and 8 are in the same place. 3,7 and 5,4 were swapped, and in the rotation, they correlate with each other as pistons that come to TDC at the same time. 5 and 3 do and 7 and 4 do, so you won't have any piston to valve contact problems.
LordMustangGT
118
Port Orchard, WA
Sep 26, 2007
  • Sep 26, 2007
ok ok, I took a 5.0 out of a 86 t-bird and put it in my 88 5.0, only thing that has to be changed it the cam. I took the HO cam out of my blown HO and put it in the Non-HO and runs like a champ. The firing orders are different is all. Same crank and rods, but had the flat-top pistons and the E6 heads.
Matt
F
facemelter71
60
cincy
Sep 26, 2007
  • Sep 26, 2007
HO cam wont work in A non HO block without the correct lifters dog bones and retainer for the lifters,unless you find a set that have a guide bar installed.If not then you have to drill and tap holes in the lifter valley to use a roller cam in a non roller(non HO) block.Some thunderbirds came with a HO roller engine.
cenok is family
1,409
69
79
Norman, Ok
Sep 26, 2007
  • Sep 26, 2007
the intake in non-HO cars was more restrictive too, but you said your car's carbed so that doesn't matter for you.
Darkwriter77
Resident Ranting Negative Nancy
5 Year Member
Jul 1, 2005
315
283
134
Apache Junction, AZ
Sep 26, 2007
  • Sep 26, 2007
I think there's a bit of confusion with what some here are considering a non-HO 5.0. From '86 to '90, the lo-po 5.0 and the HO 5.0 were the same BLOCK - both were rollers, same crank, same rods. As stated, the pistons were different, as were the cam, heads (E6 versus E7), UPPER intake manifold (lower was the same for both), EGR spacer, throttle body, ECM, fuel rail, and injectors.
Swapping a non-HO to HO specs involves swapping most of the above. The HO upper intake will actually mount backwards onto the lower manifold without any modifications, although you'd need to flip-flop the butterfly on the throttle body, and either bore out the old EGR spacer or bypass the coolant lines on an HO spacer, if using an HO in a non-HO application, such as a Crown Victoria.
The "old" 5.0 that others may refer to are the old non-roller blocks (pre-85, I think), which are a completely different animal in a lot of ways. Different fuel delivery system, different heads, pistons, cam, etc.
vristang
4,933
101
124
Seattle
Sep 26, 2007
#10
  • Sep 26, 2007
  • #10
Although it doesn't pertain to the Original question, others have hinted to it...
The ecu used on the HO cars is different than non-HO.
The HO ecu (as found in a 88-93 Mustang 5.0), uses the HO firing order to fire the Injectors Sequentially.
Using a non-HO cam with an HO ecu, will result in issues...
http://www.fordfuelinjection.com/?p=92
jason
Darkwriter77
5 Year Member
Jul 1, 2005
315
283
134
Apache Junction, AZ
Sep 26, 2007
#11
  • Sep 26, 2007
  • #11
*ahem* Already specified two posts above that the ECM needs to be swapped over when going from lo-po to HO 5.0. But good info, anyway...
LordMustangGT
118
Port Orchard, WA
Sep 26, 2007
#12
  • Sep 26, 2007
  • #12
the no-ho block all I had to do was swap to a HO cam. It was already roller.
F
facemelter71
60
cincy
Sep 27, 2007
#13
  • Sep 27, 2007
  • #13
Then that block came from a roller 85 or 86 with the flat top pistons.So then it was an HO engine.
D
Engine HO cam in non HO roller block ‘93 f150
  • DanC1993f150
  • Mar 21, 2026
Fox 5.0 Mustang Tech Mar 29, 2026
General karthief
G
Engine Is this a HO or non-ho?
  • Gnfanatic
  • Nov 8, 2024
Fox 5.0 Mustang Tech Nov 9, 2024
Gnfanatic
G
H
Engine 1987 5.0 HO vacuum hose locations
  • harryhaber
  • Jun 20, 2025
Fox 5.0 Mustang Tech Jun 21, 2025
limp
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
