I need help from the Ford gurus because my 1965 Mustang has officially become possessed.
The build:
I carefully pump up the Trick Flow lifters (TFS-21400004-16) in oil by hand. They seem perfect, no issues with compression or feeling of them being stiff or stuck
I install them.
I prime the oiling system with a drill.
I fire the engine.
Success.
It runs.
Oil pressure is good. 45-50 cold and 30-35 at operating temperature.
No strange noises.
At this point I'm standing in the garage feeling like Carroll Shelby himself.
"Hell yeah. I nailed it."
Then the misfires begin.
Okay, maybe injectors.
Pulled all the LU47s and had them flow tested and they are perfect.
Okay, maybe ignition.
New performance distributor.
New cap.
New rotor.
New wires.
New plugs.
Still misfiring.
Now the weird part begins.
The cylinders that are misfiring seem to change.
One day it acts like one cylinder has a valve hanging open.
The next day that cylinder is fine and another one is dead.
So I tear the engine apart.
I discover three lifters that are pumped up completely solid.
Not stiff.
Not hard.
SOLID.
The plungers absolutely will not compress.
When resetting lash they literally hold the valves open.
No amount of finger pressure or vice with a v cutout and old pushrod cut to fit and compressed by spining the vice will move them.
So I disassemble the messed up lifters, clean them, reassemble them, compress them in oil, reinstall them, reset lash, ran a compression test showed 185-195 PSI on all 8.
And i thought i had won.....
Nope.
Different lifters start doing the same thing.
At this point I'm questioning every life decision that led me here.
So I decide the Trick Flow lifters must be bad and order brand-new Ford Racing M-6500-R302 hydraulic roller lifters.
The box arrives.
Several of the BRAND NEW lifters are already completely solid and impossible to compress right out of the package.
Now I'm standing in my garage holding brand-new lifters and asking questions like:
If you've seen hydraulic roller lifters repeatedly pump up solid and hold valves open after the engine warms up, please tell me where you'd start looking because I'm running out of ideas, money, and emotional stability.
The build:
- 1965 Mustang
- SN95 5.0 roller block
- Trick Flow 11R Top End Kit from TRE
- Holley Multi-Port EFI intake
- Holley Terminator X Max
- LU47 injectors
- T5 transmission
- Confirmed correct 7.050" pushrods
- More money than I care to admit
- Ford 9 inch
- Subframe connectors
- Mike Maier mod bar
- Coilover suspension
- Caltracks *up next*
I install them.
I fire the engine.
Success.
It runs.
No strange noises.
New cap.
New rotor.
New wires.
New plugs.
Still misfiring.
Not stiff.
Not hard.
SOLID.
Nope.
The box arrives.
- What are they chances that two different hydraulic roller lifters actually be bad out of the box?
- Why do the affected cylinders seem to change?
- Why do some lifters become solid enough to hold valves open?
- Is there some oiling issue causing them to pump up and never bleed down?
- Is this normal and I'm just an idiot?
- Or has my Mustang become self-aware and decided to bankrupt me?
- Correct 7.050" pushrods confirmed
- Hydraulic roller cam
- Roller block
- Multiple lifters becoming solid
- Cylinders affected seem to change over time
- Injectors tested good
- Ignition components replaced
- Compression test was good
