5.0 with steering problem
MacDiesel
74
My 89 mustang gt used to drive like crap, so i changed the rack & pinion and the power steering pump and it still drives like crap. When i hit a bump it jerks me around. It doesn't do that so bad now with the new rack. Also, the steering wheel has a lot of play in it. Basically, it seems like I am all over the road. Could this maybe be in my head because i have a 98 cobra that drives perfectly, and that is what i am used to? Thanks to anyone who helps. I am angry that i spent about $200 on a new rack, pump, and hoses for nothing.
If you put a new set of shocks/struts on you will probably find that you eleminate a majority if not all of what you are decribing. I just put some koni reds on the back of mine and man what an improvement. Koni's Reds have gotten fairly cheap these days....summit charges $99/shock and $149/strut. As soon as I get the money Im gonna get the struts as well.
If the struts are good, an increase in caster via Caster/Camber plates will help. Setting the caster to 3 degrees on each side will eliminate road wander if everything else is in good shape.
The last few words of the above statment are the kicker..."if everything else is in good shape". That means struts, tires, alignment, ball joints and outer tie rod ends. A really good front end shop can eliminate most of the things you aren't familar with testing. Find one that will let you watch & ask questions while they are working on your car. Take what you learn and use it to fix your problems.
For a long time my car was kind of drifty and didn't have a real tight feel. I just had the lower control arm bushings replaced and what a difference. 130k had taken it's toll and some of my bushings were pretty loose, the new ones really improved the way the car handles. Just another thing for you to check when you're under there.
