  • SN95 4.6L Mustang Tech
5spd to Auto???
  • Thread starter Thread starter 03MGT
  • Start date Start date Sep 20, 2005
03MGT
199
  • Sep 20, 2005
Im going to be putting on a blower this spring. Im thinkg with all the power ill be making that it would be better to have an auto.. How much money would it cost do due that?? Aslo would an auto tranny from another mustang just be a direct swap????
tomustang
Psychotic Member
3,434
McLean Hospital
Sep 20, 2005
  • Sep 20, 2005
Find someone in your area that wants to do an auto to 5sp swap
win, win you know.
03MGT
199
  • Sep 20, 2005
Is it expensive to do this swap???
tomustang
Psychotic Member
3,434
McLean Hospital
Sep 20, 2005
  • Sep 20, 2005
if you do it yourself, no
03MGT
199
  • Sep 20, 2005
If i was gonna do it myself you think I would ask How Much It Would Cost To Do ITTTT???
03MGT
199
  • Sep 20, 2005
I found a tone of 4R70W trannys on ebay for under one grand.. It cant be to expensive do do this swap right???
Dark Knight GT
I can't get it up......ok that didn't sound right.
May 26, 2003
3,653
Ozark, Missouri
Sep 20, 2005
  • Sep 20, 2005
Ok. Before we go any further, lets get a few things correct.
First off, if you're planning on doing this swap yourself, I have to ask are you a mechanic, and if not, have you ever done a transmission swap before ? If you don't know what you're doing, you can end up doing more harm than good. If that is the case, then it's better to let someone who knows what they're doing do it for you.
Second, if you're planning on putting a blower on the car, then what might help us help you in terms of advice is for you to tell us how much boost and power you're planning on making. If you're planning on making over 400rwhp, then you might want to look into either buying a 4r70w automatic and upgrading its internal parts, or buy a high performance 4r70w transmission from some place like Performance Automatic or Lentech Transmissions.
If you decide to upgrade a stock 4r70w, I recommend you read up on the tech articles over at www.tccoa.com Their tech articles on the 4r70w transmission are the best at supplying info. on the 4r70w automatic transmission.
Either way, you need to get a transmission cooler for that automatic, or it will not last. Also, be sure to run a good transmisison fluid through there, or it won't last either. Whatever fluid you get, make sure its at least Mercon V or superior.
Let us know if you have any other questions.
DropTopPony
Noob Slayer
2,570
south jersey
Sep 20, 2005
  • Sep 20, 2005
being rude is not a good way to get someone to help you! just a FYI
C
crazystang05
172
  • Sep 20, 2005
I would think a manual is stronger than an auto, I would personally do the 03/04 cobra's six speed manual. But I dont know much about tranny's so...but I do know driving one is alot more fun than an auto.
03MGT
199
#10
  • Sep 20, 2005
  • #10
I wast tring to be rude I guess It did come off as rude tho....
Blown00GTAuto
182
Washington DC
Sep 20, 2005
#11
  • Sep 20, 2005
  • #11
Stock 4R70W's are quite strong although mis-use and abuse will break either type of trans. If I was getting an auto put in as a replacement it would be a built one though.
In drag racing its easier to be consistent with an auto, so an auto can become more of an advantage than a preference. As far as fun and performance, I used to think autos were not the way to go until I rode passenger in a friends heads/cam stalled auto Nova ....on the spray .
DBMSTNG
I fantasize about it being BIG!
2,120
not quite here
Sep 20, 2005
#12
  • Sep 20, 2005
  • #12
the 4R70W is stronger than the stock 5speed. just replace the clutches in the 4R70W and it can handle 700ft/lbs. from what i've heard.
J
jimfitzgerald
6,672
#13
  • Sep 20, 2005
  • #13
Get your blower first and see how much power you make and how well you do with the car. You may be fine with the 5 speed. If you get much over 500 rwhp, then you probably will want to consider a built automatic. A built 4R70W can get expensive. A C5 is lower cost, but you lose OD for the street. There are some other alternatives also.
P
pigpen22
Layton, UT
Sep 21, 2005
#14
  • Sep 21, 2005
  • #14
Where are you? I have an auto that I was thinking of swapping for a 5 speed.
E
4.6l auto to 5.4l 6 speed
  • EastanF5
  • Jan 22, 2026
SN95 4.6L Mustang Tech Jan 22, 2026
EastanF5
E
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
Lost my Foxbody
  • Mhalc1
  • Feb 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 17, 2026
Mhalc1
A
Procharger install/prep questions
  • ahratrew
  • Nov 22, 2025
SN95 4.6L Mustang Tech Nov 26, 2025
