6 cyl axle
  • Thread starter Thread starter nick_94cobra
  • Start date Start date Feb 9, 2010
N
nick_94cobra
25
  • Feb 9, 2010
what spline are 6 cyl axle shafts? if they are the same spline as the v8 shafts, could you put v8 shafts in a 6 cyl rear end?
thanks
shoguun
184
  • Feb 9, 2010
not 100 percent sure but im gonna say no. V8s are 28 and 31 spline. Not sure what 6cyl is but 8 and 9 inch have a 3rd member that comes out. 6cyl dont
degins
361
Texas
Feb 9, 2010
  • Feb 9, 2010
thanks
They are 24 spline.
N
nick_94cobra
25
  • Feb 9, 2010
alright, thanks for clearing that up. now i'm leaning towards pulling my shafts and having them filled and redrilled for 5 lug. all i'm looking to do is run 5 lug wheels, is this a safe way to do it? i'm going with discbrakeswap.com front 5 lug swap. also, the pattern i want is 5x4.5 correct?
thanks
shoguun
184
  • Feb 9, 2010
if you want to change the lug number then just buy an 8 or 9 inch. your getting way better value cause they are stronger probably cheaper than redoing just the axles to fit your 6cyl and you dont need to do any axle swapping. 5x4.5 is the size you want.
rbohm
6,698
550
204
tucson,az
Feb 10, 2010
  • Feb 10, 2010
degins said:
They are 24 spline.
i was thinking 25 spline, but either way you are right, they are smaller than the 8" axles.
thanks
you can redrill the axles, and the drums, to a 5x4.5 bolt pattern, but why go through all that when you can grab an 8" rear end from a granada, or find someone in your area that has swapped a 9" into their stang, and pick up the rear end for about the same money as you would spend redrilling the axle flanges and drums, and you get a stronger rear end to boot.
67 coupe 6 cyl. Carb too high hits hood, required carb,?has cooleed heater hoses on base below carb.
  • Brian S.
  • May 7, 2026
Classic Mustang Specific Tech May 7, 2026
Realmongo
4.6 spitting o-rings out of 2 injectors
  • skidad
  • Sep 30, 2026
  • 2 3 4
2K
1996 - 2004 SN95 Mustang -General/Talk- Nov 4, 2026
skidad
Differential noise over bumps
  • sharkrat
  • Apr 10, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Jun 18, 2026
TPony
C
Inline 6 wanted 200 ci
  • Capnkev
  • Mar 2, 2026
  • Want to Buy
Want to Buy Jul 16, 2026
Capnkev
C
H
Misfire cyl 2 under 3200 RPM, not the coil or injector
  • Hydranmenace
  • Nov 14, 2025
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Nov 14, 2025
Hydranmenace
H
