  • SN95 4.6L Mustang Tech
6 quarts????
  • Thread starter Thread starter PSCBrenden
  • Start date Start date Aug 25, 2004
First Prev 2 of 2
40th GT
916
Lawrenceville, GA
Aug 25, 2004
#21
  • Aug 25, 2004
  • #21
An 01 shouldn't take more than 5. Someone else chime in if I'm wrong.
crew_dawg16
445
DeKalb, IL
Aug 25, 2004
#22
  • Aug 25, 2004
  • #22
just put 5 in your 01, if that doesn't read high enough on the dipstick, put in some more, you will know from then on how much it takes.
StngStr
616
Central Florida
Aug 25, 2004
#23
  • Aug 25, 2004
  • #23
My 03 takes 6. I use 0w-20 Mobil 1.
9
93octane
46
#24
  • Aug 25, 2004
  • #24
I think 99,00 and some 01 use 5qts and the rest use 6qts. Don't know if its the dipstick or what but some do use 5 and others 6. If both engines are the same then one engine is running 1qt low or the other is running 1qt over. So my guess they are diffrent somehow.
Turbo92PGT
746
Auburn Washington
Aug 25, 2004
#25
  • Aug 25, 2004
  • #25
I work at jiffy lube. An 00 or 01 GT came in (cant remember what year) and it only took 5 quarts. I talked to her a little bit. Too bad it was an auto She was pretty hot I told her that mine takes 6 quarts and that she should check out stangnet. Was gonna try and sell her my intake lol
Sleepy1
807
Chicago, IL
Aug 25, 2004
#26
  • Aug 25, 2004
  • #26
My 01 owners manual says 5 quarts. The oil level be at the top of the dipstick with 5 quarts.
H
huesmann
332
#27
  • Aug 26, 2004
  • #27
Turbo92PGT said:
My 98 uses 8 quarts per oil change.
6 when i change the oil and filter
1 about 3 weeks later
another 1 about 3 more weeks later
Leaky-ass piece of ****
There, fixed it for you.
DTMach1
240
Virginia Beach, VA
Aug 26, 2004
#28
  • Aug 26, 2004
  • #28
as per scott hoag...6.5 qt's...I don't know if that's just 4v's...or just mach's or what
01LaserRedCobra
318
#29
  • Aug 26, 2004
  • #29
I have a 01 cobra and I did a experiment. I filled the car up with 6qts (it showed 3/4 of the way between the low and full line)... and started the engine let it run to operating temperature. After it was running, the dipstick was bone dry not even anything on the tip. So I also believe on the 4V engines they suck the oil up for the massive heads... So I am going to start using 6.5 qts from now on...
01LaserRedCobra
318
#30
  • Aug 26, 2004
  • #30
Granted the engine will of course consume the oil but I am wondering how much is left in the pan at operating temperatures? Especially if you are driving hard through corners???
F
ForPointSex
395
Mercer, NJ
Aug 26, 2004
#31
  • Aug 26, 2004
  • #31
My takes exactly 5 qts to show full. I have one of the first romeo blocks, so it might have the old dip stick. My pulley's are older type (96-01) too.
I use Valvoline 5w20 and change it every 3K miles.
T
tjm73
2,418
Rush, NY
Aug 26, 2004
#32
  • Aug 26, 2004
  • #32
To end/answer this question we need someone with each of the following cars to look at their owners manual and reply with what it says.
1996 GT
1997 GT
1998 GT I'll take this one - Owners Manual says 6 qts for 4.6 V8
1999 GT
2000 GT
2001 GT
2002 GT
2003 GT
2004 GT
That should put this question to rest. And if you have a 4V car, chime in with your year and what your manual says too if you like.
kevenw98
12
San Antonio, TX
Aug 26, 2004
#33
  • Aug 26, 2004
  • #33
My Mach takes 6 3/4 quarts. Mobil 1 0W20
chevylover
190
Castro Valley, CA originally St. James Missouri
Aug 26, 2004
#34
  • Aug 26, 2004
  • #34
99 GT: owners manual says 5, I changed it today and by golly their right. 5 quarts puts it at the top of the MAX on the old dipper.
Speedy Lube kept telling me 6 and charging me for an extra Q@ $6 per.
So I said thank you I'll do it myself.
T
tarch
My 8V > 4V > 2V
3,073
Redmond, WA
Aug 26, 2004
#35
  • Aug 26, 2004
  • #35
my 01 takes 6 and it's an 01
so i guess 01's take 6
OR
the windsor/romeo issue comes up once again!
boostedpony
San Antonio
Aug 26, 2004
#36
  • Aug 26, 2004
  • #36
Yes, mine is 6 also even though I went round and round at my local oil change depot, they were saying it was 5 my manual says 6 . It definately is 6 quarts..
First Prev 2 of 2
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
E
4.6l auto to 5.4l 6 speed
  • EastanF5
  • Jan 22, 2026
SN95 4.6L Mustang Tech Jan 22, 2026
EastanF5
E
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
L
A/C doesn't work after long drive
  • lking78
  • Jun 23, 2026
  • SVT Tech Forum
SVT Tech Forum Jun 30, 2026
Oil choice for after break in period.
  • Sask84gt
  • Feb 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 14, 2026
Praetorious
P
