6 speed or 5?
  • Thread starter Thread starter triostang
  • Start date Start date Sep 8, 2004
triostang
142
  • Sep 8, 2004
I am seriously considering a tranny swap, from my stock fmx to a tremec 5 speed or 6, within the next few months. I can find a donor car for parts but I wanna go for 6 speed. Is there a big difference between the 5 and 6 speed swap? Do you go about and do them both the same way?
skywalker
733
Pensacola, FL
Sep 8, 2004
  • Sep 8, 2004
You realize that there will likely be alot of fabrication involved with a tremec?
triostang
142
  • Sep 8, 2004
thats one of the first thing that poped into my head, im up for it.
LMan
1,246
Mom's basement
Sep 8, 2004
  • Sep 8, 2004
you need to query 'gp001' He has a 6-speed in his Mustang....very nice car!
gp001, you out there?
T
tjm73
2,418
Rush, NY
Sep 8, 2004
  • Sep 8, 2004
A 6 speed will cost almost double that of a 5 speed.
triostang
142
  • Sep 8, 2004
I found a 6 speed that i want already, richmond, think its good? i realized that is the same one i think as gp001's
G
gp001
4,401
So. Cal.
Sep 8, 2004
  • Sep 8, 2004
Here is the link to my swap info. http://www.2mfffabshop.com/rod.htm
Are you buying the tranny new or have you found a used one?
triostang
142
  • Sep 8, 2004
a found a used one from a guy, but never used it. he got a g force instead, if i need to i will get a new one, but the used one is cheaper and i was hoping of going that direction.
G
gp001
4,401
So. Cal.
Sep 8, 2004
  • Sep 8, 2004
Just keep in mind there are a few different Ford versions that may affect which other parts you will need (flywheels, clutch, bellhousing, crossmember, etc). The differences will be in the input shaft diameter, input shaft splines, and input shaft length. You can get more info here
http://richmondgear.com/01sixspeed.html
triostang
142
#10
  • Sep 8, 2004
  • #10
I just found one on ebay, http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=7920746640&category=33733
what do you think? thanks for the help
G
gp001
4,401
So. Cal.
Sep 8, 2004
#11
  • Sep 8, 2004
  • #11
That looks to be the 1 1/8" - 26 spline (not 21 spline) trans that they have modified to use with a big block motor (cut down the input shaft diameter). I don't know if you have a big block or not. The second thing to consider is that you don't have alot of choices for clutches for the 1 1/8"-26 spline input shaft as compared with the 1 1/16"-10 spline models. Also, this model has the shorter input shaft, so you would need a bellhousing/ scattershield for a top loader and not a Richmond
triostang
142
#12
  • Sep 8, 2004
  • #12
so would it be possible to have it on a small block (347 still with machinist)? Im not really sure as to which clutches i will be needing though. Will it be a big deal not having a wide variety of clutches to use? sorry im not the smartest in that area
G
gp001
4,401
So. Cal.
Sep 8, 2004
#13
  • Sep 8, 2004
  • #13
The cutting down of the pilot of the input shaft may be a problem. The pilot may not extend into the bearing/bushing. The small number of clutches just means you get to spend more as the ones available are usually the higher end units.
triostang
142
#14
  • Sep 8, 2004
  • #14
so you would suggest going with a richmond that hasnt been cut up? i will have to look it up
E
4.6l auto to 5.4l 6 speed
  • EastanF5
  • Jan 22, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jan 22, 2026
EastanF5
E
SOLD 1986 Mercury Capri 5.0 5-speed
  • blackmerc
  • Jul 29, 2026
Fox Body Mustangs For Sale (1979-93) Aug 24, 2026
General karthief
For Sale 1993 Mustang SVT Cobra - Black - 5 Speed - 88k Miles - Single Owner
  • Buddy Jake
  • Jun 16, 2026
Fox Body Mustangs For Sale (1979-93) Jun 20, 2026
Habu135
Any 1 find any decent blackfriday sales for Foxbody or car stuff?
  • rednotch
  • Nov 29, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 19, 2025
rednotch
R
Misfire at high rpm! Help
  • Ryanm2018gt
  • Jan 2, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Jan 17, 2026
highplace11
H
