6 speed or 5?
triostang
142
I am seriously considering a tranny swap, from my stock fmx to a tremec 5 speed or 6, within the next few months. I can find a donor car for parts but I wanna go for 6 speed. Is there a big difference between the 5 and 6 speed swap? Do you go about and do them both the same way?
a found a used one from a guy, but never used it. he got a g force instead, if i need to i will get a new one, but the used one is cheaper and i was hoping of going that direction.
That looks to be the 1 1/8" - 26 spline (not 21 spline) trans that they have modified to use with a big block motor (cut down the input shaft diameter). I don't know if you have a big block or not. The second thing to consider is that you don't have alot of choices for clutches for the 1 1/8"-26 spline input shaft as compared with the 1 1/16"-10 spline models. Also, this model has the shorter input shaft, so you would need a bellhousing/ scattershield for a top loader and not a Richmond
so would it be possible to have it on a small block (347 still with machinist)? Im not really sure as to which clutches i will be needing though. Will it be a big deal not having a wide variety of clutches to use? sorry im not the smartest in that area
The cutting down of the pilot of the input shaft may be a problem. The pilot may not extend into the bearing/bushing. The small number of clutches just means you get to spend more as the ones available are usually the higher end units.
