65 Wiring & Start
  • Thread starter Thread starter blu2u
  • Start date Start date Jan 18, 2009
blu2u
12
  • Jan 18, 2009
Battery is hooked up. Solenoid is hooked up.
Must other wires (dist-coil) be hooked up so that when I turn the key, I will get idiot lights? I initally was trying to test the voltage at the positive side of the coil. Thanks
Tim65GT
1,149
West Texas
Jan 18, 2009
  • Jan 18, 2009
What idiot lights? If you mean the Alternator light, It gets 12volts when the ignition is on and it gets a ground through the alternator when it is not charging.
So what voltage did you get at the coil?
blu2u
12
  • Jan 18, 2009
Your right of course, alt light. What I mean is, when I turn the key on, I should have a red light. I have nothing. No wipers - nothing. Of course, no voltage at the coil.
Wayne
BarnStang
1,260
Hagerstown, MD
Jan 18, 2009
  • Jan 18, 2009
You won't get wipers unless you have the main power feed to the fusebox hooked to the solinoid, and the fuse(s) in place. THis will also apply to getting power to the coil wire, which is fed from the ign switch. THere should be a large ring term in the harness coming from uner the battery tray.
Tim, do you have a simple diagram? I think the whole 65 diagram set will not be much help yet...
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
M
85 mustang 5.0 cranking in run position
  • Mamaclean
  • May 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 1, 2026
General karthief
Electrical Starter solenoid out of space?
  • 387lx
  • Jan 22, 2026
Fox 5.0 Mustang Tech Jan 23, 2026
387lx
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
C
Electrical Under dash wiring
  • ChicagoMustang
  • Apr 17, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
