I think I've got a short somewhere in my wiring and I really got to get this fixed here within a two month time span. I'm definitely not a pro when it comes to wiring, so any help would greatly be appreciated. My battery drains real easy, I have to charge it every time I want to try and start the engine.
I've seen before where someone recommend disconnecting the negative to the battery and hooking up a test light. Where do you hook the wire clip of the test light to, and also where do you touch the screw-driver part at? Do you clip that on the negative cable and touch the (-) post on the battery? (I have side-terminals BTW) Once I get this figured out, I then disconnect the few fuses that I have one by one to determine which circuit the short is on and proceed looking at the wiring from there?
