67' exhaust question
  • Thread starter Thread starter mobius_1
  • Start date Start date Mar 3, 2004
M
mobius_1
27
  • Mar 3, 2004
Well I'm trying to decide what exhaust system to get for my 67' stang. I have setup to run dual exhaust now and I'm trying to decide between the stock GT exhaust with the resonators and the transverse muffler or a flowmaster kit. How does the stock GT exhaust sound? I've never heard it, is it aggresive kinda like flows? Any advice would be great. Thanks.
67GTA-FB429
777
Tri-Cities, Wa
Mar 3, 2004
  • Mar 3, 2004
The transverse muffler would be rather restrictive, IMO. A true dual exhaust will give much better flow, wspecially if you use some sort of cross-pipe.
mfp4073
387
Hells Ditch, FL
Mar 3, 2004
  • Mar 3, 2004
Well hello there said the spider to the fly and step into my parlor! I have a 67 that had a single exhaust when I purchased it, then went with longtube headders and a gt style setup. Most recently I upgraded to a 2.5 inch 40 series/2 chamber flowmaster setup. The 2.5 flowmasters are REALLY free flowing.....I was within 2 hp with my dumps open and closed (they are just behind the h pipe on my car). The flowmaster is definately a differnt sound. Much louder and that can get to the point of defining on long trips. The gt setup is pretty quiet if you ask me, but it also sounds good. It has rumble, but not nearly the rumble of flowmasters. You will probably spend more on the flowmaster setup too. The best I found for just one 40 series was like $85.
It will depend a lot on what you want to do with the car. I went 2.5 inch as I needed the flow and wanted the sound. But I also dont drive the car all the time, its a weekend warrior these days. I probably would have kept the gt setup if it was still my daily car and I didnt have as hot a motor in it.
Also realize, you can probably put a gt kit in yourself with some headache and skint knuckles. There are no complete flowmaster systems for 67-68 mustangs at this time..... so you will have to get it installed by a shop.
67coupe351w
424
Portland, OR
Mar 3, 2004
  • Mar 3, 2004
Ya, 40 series flowmasters cost $85 for the delta flow technology version but are $60 for no delta flow technology. I got both of those prices from www.summitracing.com
Delta flow is supposed to make interior resnance less...I have dual 40 series with delta flow and i honestly dont wanna know what the non-delta flows would sound like lol. Although this may have somethign to do with my exhaust dumping at the rear axle though.
The dual flowies sure sound good though.
I
INDSKYS
245
CALIFORNIA
Mar 3, 2004
  • Mar 3, 2004
NOOOOOOOOO THE FLOWMASTER AMERICAN THUNDER WHICH LIST,S AS 65-66 WILL FIT THE 67-8 I PUT IN MY 68 AND IT SOUNDS WICKED . ITS A 2.5 ALL THE WAY THRU .IF U ARE MECHANICALLY INCLINED U CXAN DO IT . U HAVE TI GRIND OFF A PORTION OF A BRACKET IN THE REAR OF CAR WHERE A HANGER GOES IN. AND U HAVE TO FISH THE PIPE FROM COLLECTOPR TO HEADERS . I JUST HEATED MY PIPES WITH A TORCH AND BENT THEM TO LINE UP THEN HAD A SHORT STRAIGHT PIECE FABBED TO MAKE UP THE LENGTH. THE FIT WAS PERFECT AND FIT OVER MY TCP SUB CONNECTORS ALSO . VERY NICE KIT AND REASONABLE COST. MAKES MY STOCK 302 SOUND BUILT .
U
usedtobe 67p51d
208
let's tear up golfcourses and build race tracks!
Mar 3, 2004
  • Mar 3, 2004
I have a heathy 331 2 1/2" pipe with an "X" ans delta 50's and it's loud. not too loud but louder than I care fo'
2nd Mustang
2,488
Southern California
Mar 3, 2004
  • Mar 3, 2004
I have 2 1/4" dual exhaust with an H-pipe into 2 turbo mufflers. Sounds healthy enough at idle and not very loud at cruising speed, but watch out when you floor it!
Oops, forgot to mention I also have full length headers.
mfp4073
387
Hells Ditch, FL
Mar 3, 2004
  • Mar 3, 2004
I was told by flowmaster that it would not fit...oh well. Guess you proved different!
M
mobius_1
27
  • Mar 6, 2004
thanks for the tips guys...I'm still debating what to do. I just installed a nice stainless steel catback kit on my 98GT from Ford Racing and I like way that sounds maybe I can get a set of mufflers from Ford Racing and fab up my own exhaust. I mean I'm a welder fabricator I should be able to come up with something. Thanks for the advice.
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
G
Exhaust
  • GoldenRuleClassics
  • Apr 21, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 21, 2025
2000xp8
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
Progress Thread 91GTstroked 90 7 up convertible build
  • 91GTstroked
  • Apr 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 22, 2026
91GTstroked
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
