67 Trunk Trim
Bonzo
Wales
I have just purchased the chrome trunk and qtr panel trim from NPD for my 67 coupe.
The car did not have these before.
It looks like I have to re drill the trunk holes with the fixings provided.
But how do I fix the qtr panel strips. It does not seem obvious.
Any advice would be appreciated.
Tony
The trim you are speaking of is the standard trim on a 68, right? All of that trim was attached with the type of trim clips that use nuts on the inside to secure so you will have to drill holes in the quarter caps also.
when doing the rear end cap chrome (either side of trunk), take the end caps OFF the car first (remove three nuts inside the trunk). On the inside you will see where you are supposed to drill (there are three reliefs cast onto the inside).
