67 Vacuum problems
  • Thread starter Thread starter Malexanders1967
  • Start date Start date May 6, 2004
M
Malexanders1967
  • May 6, 2004
I have a problem that I can’t figure out. My car sputters and very low speeds but idles fine. If you get in the gas a lot it runs fine for the first part of the take off and then starts to sputter again. I have replaced some of the vacuum hoses and it seems to work for a little bit and then starts to do it again. ANY Solutions????
slapper
447
  • May 6, 2004
Message board troubleshooting 101:
Is this a condition that suddenly occured, or has it been around for a while?
Have you recently done any work which may have influenced this condition?
Verify if it is indeed a vacuum leak.
There's a couple of easy ways to do this:
While the engine is idling, use some spray carb cleaner, and spray around the vacuum hoses and lines, including where they connect to items. Take your time and do a very clse visual inspection as well. The engine speed will increase when the carb cleaner gets sucked in.
Get a vacuum gauge and connect it to a vacuum port. See if it's reading a steady number, or when it's fluctuating.
Of course check the obvious such as, dirty air filter, dirty fuel filter, tight and clean battery connections, etc.
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
G
Idle surging after warm up
  • GALLY3309
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2026
A/C Issues
  • Boats90GT
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
Mcmahst
J
Emission problems
  • jls.zmmr
  • Feb 5, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Feb 7, 2026
AeroCoupe
M
2001 cobra coolant crossover delete
  • Mike3
  • Jul 5, 2026
  • SVT Tech Forum
SVT Tech Forum Jul 12, 2026
Mike3
M
