7 70ivygreen Member Jan 16, 2007 21 2 14 Auburn, Alabama Aug 20, 2019 #1 Aug 20, 2019 #1 Suspect that the ignition condenser (capacitor) may be defective. Coil, points, wiring etc. appears to be ok. Any suggestions?
tos Founding Member Apr 27, 2001 896 68 59 Cincinnati Ohio Sep 4, 2019 #2 Sep 4, 2019 #2 Well condensers are cheap but First if you have a multimeter then check to see that you are getting 12v to the positive side of your coil when your ignition is in the on pos. if so then check your point setting.
