69 Steering
The drag link , the hole for the idler and the hole for the pitman arm will be the same distance from the frame rails on both sides ,then you can adjust the tie rods for each side until the tires are straight .You can measure the tire front and back side from the frame rail ,that should get you close enough for the alignment shop .A good alignment shop will square up the front end and the steering wheel .
