69 Tach wiring
  • Thread starter Thread starter SwedeMach1
  • Start date Start date Feb 26, 2007
SwedeMach1
Trollhättan, Sweden
Feb 26, 2007
  • Feb 26, 2007
I've got a 69 mach 1 that came without Tach. Now I've purchased an original instrument cluster with tach and I've discovered that the printed circuit wiring differs between the clusters. Does anyone knows if I can rearrange the wiring in the multicontact that connects to the cluster or do I need to cut the wires behind the multicontact and reconnect them in the correct order? Is there anything else that has to change? The cluster with Tach has warning lights instead of gauges for some of the functions (such as oil preassure) but I assume I only need to change the senders in those cases. I appreciate any advices in this matter.
Thanks,
Patric
Max Power
1,774
St Paul
Feb 26, 2007
  • Feb 26, 2007
http://www.boss302.com/tach.htm
SwedeMach1
Trollhättan, Sweden
Feb 27, 2007
  • Feb 27, 2007
Max Power!
You rule
Thanks for the information. I was seconds away from putting back the standard cluster but you saved the day. I'll be splicing and cutting this weekend! I hope the cluster works....
Thanks again!
Patric
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
P
Electrical 2001 GT Overcharging
  • PseudoGT
  • Dec 3, 2025
SN95 4.6L Mustang Tech Dec 13, 2025
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 4, 2026
2000ElectricGreen
J
'96 Cobra: A/C gets weak and engine misfires under load when warm
  • jruhnke
  • Oct 22, 2025
  • SVT Tech Forum
SVT Tech Forum Nov 20, 2025
nickyb
