6G Alternator Help!
  • Thread starter Thread starter DRock9
  • Start date Start date Jul 14, 2008
D
DRock9
359
  • Jul 14, 2008
I have the 6G Alt in my car, and at idle the volt meter needle likes to bounce up and down along with my idle but when I am cruising the needle stays at a solid 14V. My idle will only vary a little bit, maybe 50rpm, but my voltage will go from like 14V down to 11V and then bounce from 11V to 8V. Is the voltage regulator shot on the alternator? If so then why does it stay steady when I am cruising? Is my battery not good enough?
Thank you.
stykthyn
5,232
2,652
223
gainesville
Jul 14, 2008
  • Jul 14, 2008
did you upgrade all the wiring? kind of sounds like a bad ground. I had a bad ground when I did my first 3g swap and it bounced like that.
HISSIN50
34
129
Jul 14, 2008
  • Jul 14, 2008
Out of curiousity, what color is the regulator?
It sounds like there's possibly a regulator issue or a loose power connection.
Good luck.
D
DRock9
359
  • Jul 15, 2008
I checked the ground near the battery and it was fine, also I tightened the nut down on the back a lot and actually sandwiched a piece of metal in there because the connector is an oval so that it would touch the whole connector.
I am going to go check right now to see what color the regulator is.
Thanks.
P
Electrical 2001 GT Overcharging
  • PseudoGT
  • Dec 3, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Dec 13, 2025
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
W
Electrical 91 GT Alternator Replacement Question
  • willrh111
  • Oct 22, 2025
Fox 5.0 Mustang Tech Oct 23, 2025
nickyb
A
Resolved Electrical Help Please
  • Alabama
  • Jan 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 22, 2026
AeroCoupe
