Hey guys, i got a alternator from the parts store for a 94/95 mustang gt, the part number was p7771-11-6g so im guessing its a 6g correct? I have a couple quick questions because when I search it doesn't register the 6g, and most questions are for 3g's. I got from searching that you don't need to splice the stator wire. So what do you do? Do you just discard that whole harness? Use the stock stator wire? Just leave it unplugged?
And also for the ground wire, I kept reading to run a 4 gauge ground wire from the block to the chassis? I don't get this, can someone explain what exactly this does? does the alternator harness have a ground somewhere to the chassis, and finishing that ground to the block will ground it better? I'm a little confused how that works, and where exactly is a ground wire connected to the alternator? Does the ground from the block have to be put anywhere specific?
I got this quote from Jrichker:
"Any car that has a 3G alternator needs a 4 gauge ground wire running from the block to the chassis ground where the battery pigtail ground connects"
Where exactly is the chassis where the battery pigtail ground connects? My battery is in the trunk so I am a little confused by this, again does it have to be anywhere specific, or just 4ga from block to chassis that's it.
And last question does anyone know stores that sell those fuses? I guess the fuse I want to use is a 150amp water fuse? That's what its called right? Anyone know if places like napa, ace sell those?
