8.8 axle swap revisit
74ProII
194
Bremerton, WA, USA
hey guys, I seem to remember some questions about 8.8 swaps. Well anyways while searching for another article in the stacks I found one from Mustang Illustrated, DEc 90, vol 5 #6". If someone likes I can make a scan of the article. There was a rear spring and shackle kit specifically for the purpose. I don't know if the company is there, I haven't looked yet. The kit was around $120 then.
Compnay info:
Precision Street Rods and Machines
19158 Roscoe Blvd. Dept. M.I. Northridge
CA 91324
(818)886-5018
i dont understand this whole thing with the 8.8
its a crap setup. the 8in is just as strong and can be made
pretty much bullet proof
if your gonna waste your time fitting an 8.8 in your II your a fool.
you will spend less money and time installing a 9 inch..
As far as 8' goes, try to find one. Dissapearing at a rapid rate. At least ones that do not require major rework. As to that point why bother use a 9". Let alone the expense of a 9" or built 8". You can pick up a t-loked 8.8 pretty much which gears of your choosing most times for $100 of $150. That makes it pretty much a no brainer. Especially if you add in taht Ranger and Exploer 8.8's are rear disc setups. As for mine, it's a Mark V setup, narrowed and hardened axles, bar for a rear brace it doesn't get any stronger. Other people need options taht take alot of abuse, or just the mere fact of an easier setup that updates technology and bolt patterns with a better choice of rims.
Fox 8.8 is a little wider than the stock 8", so you can use Fox 4-lug wheels with no spacers or at least thinner ones.
Turbo T-Bird 8.8 is too wide, but its disc brakes will fit the Fox 8.8.
Anyone know the width of the Explorer 8.8? It would give a cheap source of rear discs and the 4.5" 5-lug pattern.
I'm looking for a Trac Loc for my 8" now...everything I've seen is over $400 new.
"i dont understand this whole thing with the 8.8
Well I guess I have a crap setup, wasted my time, am a fool, and have more money than brains:shrug: I have an 8.8 explorer rear in my stang, setup with coil overs and ladder bars. I smile every time I mash the throttle and that foolish setup applies the power from my 347 stroker to the ground( better than ANY 8" rear I have ever had)
As far as the 8" as strong as a 9", I do not think so:bs:
Anything can be made bullet proof
I have broken 9" rears in my pro streeter ( and chevy 12 bolts)
Unless you are still living in the 60's and 70's --9" rears are not cheap anymore
Lastly, an 8.8 rear is as strong as a 9" ,it is lighter, and offers less parasitic loss internally.The 8.8 can take the punishment of a 9".Yet, it does it with less weight and drag. Oh and I did not have to cut mine, It was damn near a bolt in!:cheers:
So don't knock it just cause you can't understand it, and join us here in the 21st century. I guess EFI swaps are total crap too?
Price and availability.
When the good stuff becomes difficult to find and pricey the second tier
becomes the new good stuff.
:shrug:
its a crap setup.
By what I hear it's a coin toss.
One good thing about the 8.8 vs the 8, you can get perches for the 8.8,
The 8 has sub 3" tubes, IIRC 2 7/8 in diameter. It's a real PITA welding a
3" perch to a sub 3" tube.
I don't know the diameter of the narrow 8.8 axles but since so many are
being used in so many applications you can get the proper perches.
Thanks for digging up the artical, but
DAMN, I hate over width images!
Scrolling back and forth to read stinks, and I have a wide screen monitor!
So I did a little cropping:
If Mustang Illus or Supermotors want me to remove these graphics they can reach me HERE
74ProII, you said you had rear coil-overs? Can I see a picture please? Does this do away with the leaf springs? Was it a bolt in kit or fabrication? I need to upgrade my rear diff soon, it's a stock unit from a 2.8 MII. My 2.3Turbo should break it soon...
