8.8 Housing question????????
  • Thread starter Thread starter fourmustangs
  • Start date Start date Apr 21, 2005
F
fourmustangs
92
Houston
Apr 21, 2005
  • Apr 21, 2005
What kind of repairs can be done to the 8.8 housing?
It has a leak at the axle tube next to the housing.
Joe Jr.
207
Longmont area of Colorado
Apr 21, 2005
  • Apr 21, 2005
you could have it welded. Not sure if that is the best fix if you have something serious going on there, but its good for stiffining up the assembly also.
Joe
F
fourmustangs
92
Houston
Apr 21, 2005
  • Apr 21, 2005
It seems to be like a 100,000 mile run hard leak.
not dripping just looks wet
rd
3,316
63
109
Ocean Springs MS
Apr 21, 2005
  • Apr 21, 2005
It think the tubes are pressed into the housing and plug welded. You can just clean and weld around the joint where the tubes enter the housing.
I welded mine at two places on each side just as extra reinforcement.
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Apr 21, 2005
  • Apr 21, 2005
Mine was seeping a bit, so I cleaned it up really good and put black RTV around it and its been good to go, but my leak was really very minor, just a small wet spot nothing dripping.
87'GTstang
1,025
  • Apr 21, 2005
They are a very tight press fit. Something pro racers do before jumping to the ford 9" is indeed weld the axle tubes to the housing as this is not done in factory form. A major thing one must do is make sure there are no hairline cracks of any type in the axle tubes or the housing - if this is the case then whatever you do to try and fix it is time wasted from then on.
D
Drivetrain Where to place jackstands when servicing rear diff
  • dqureshi06
  • Oct 16, 2025
Fox 5.0 Mustang Tech Nov 2, 2025
limp
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
87 lx 4cyl to v8 project 4 lug disc conversion questions
  • 87lx428
  • Mar 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 25, 2026
87lx428
Cobra 8.8 differential rebuild shop question
  • Sestemybe
  • Aug 5, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 15, 2025
baileygruwell
Resolved Anyway, to tell where this rear end came from based on this picture?
  • x_man586
  • Jun 7, 2025
Fox 5.0 Mustang Tech Jun 7, 2025
x_man586
