You should check the pinion depth if switching gears, if your pinion is off it will change the wear pattern and could really screw things up. The shim hight will probably be the same, mine was with new ford 3.55's, but just to be on the safe side I would check. Get a intallation kit, it should come with new seals, crush sleeve, pinion nut, shims, ect. well worth it imo. I would also do the trak-lok if it needs it and the axle bearings/seals. Also you will need to set the backlash and check the wear pattern.
