I know that the sacred 9 inch is probably the way to go, but I'm on a pretty tight budget. I've got a 70 coupe with the rock stock 8 inch that I'm planning on loading with 400 HP. 70 coupe details I'd like to get the 8 inch strong enough to handle this ammount of power (with limited slip if possible) for as cheap as possible. As of now this is what I've got in the car
351C 2V .030 .010 .010
Ferrea Stainless Valves
Comp Cams 280H-10 w/matching springs
Ford Racing Pedistal Mount Roller Rockers
Weiand X-celerator Intake
Holley 750 vac- secondarys (modded body with no choke)
C4 Trans (planning on 2400 Stall with a B&M transpack)
1 3/4 primary Hooker headers w/3 inch exhaust
See all of the Details
Best guess is that I'll be around 400 HP at the crank. can the 8 inch be built to handle this with a reasonable ($300-$500) budgett?
