86 wiring prob
Graydon5oh
215
ARKANSAS
ok i have a tan wire that comes from the 10 pin harness done know where it goes cause its just hanging out when i hook it to a ground i notice no difference but when i hook it to a pos a relay by the battery starts clicking and it dumps fuel and emits black smoke. anybody have any clew where this wire goes, i think its causing the car to be slugish when on the accelerater hard.
Maybe once upon a time it was orange and had a ring terminal crimped on it. If so, it is the O2 sensor ground and you should bolt it down to one of the bolts on the back of the head or to the intake manifold.
but wouldnt that be on the o2 harness by the passenger side firewall. and i dont have the bottom part of that harness or o2s at the time(in the process of getting them right now) but i dont know its bothering me cause the car seems slower than even when i had the original motor in it and i believe it is something to do with it............... anyways any other ideas also i wanna go out and try to narrow it down this weekend even if it involves pulling the upper and lower to solve this
droptopfpm said:
i have another question could i just get rid of all of these wiring problems i have by getting a maf computer and harness kit. anybody know what exactly they come with
MASS air conversion instructions from http://www.stangnet.com/tech/maf/massairconversion.html FREE
A9L (5 Speed) computer from junkyard $100-$150
A9P (Auto or in a pinch, 5 Speed) computer from junkyard $100-$150
70MM MAF from 94-95 Mustang GT - $40-$70
MASS Air wiring harness kit $30-$85
The whole thing is probably less than $300 using junkyard parts.
A9L computers are 5 speed only
A9P computers are automatic, but will work with a 5 speed.
Conversion Harness kits & parts
http://www.mass-air.com/
http://fordfuelinjection.com/index.php?p=54
If the idea of moving & soldering wires scares you, here's a list of compatible Mass Air wiring harnesses.
bbunt302
Just for reference, here's a list of all the compatible years:
89 harness should work for 86-89 as long as you're using mass air.
90 harness will only work in a 90. (B/c of air bags and dual dash connectors)
91 through early 92 harnesses should be compatible (single dash connector, fuel pump relay under driver's seat)
Late 92 through 93 harnesses should be compatible (single dash connector, fuel pump relay under the hood)
ok im just gonna try to find this prob before i try to go the other route. any 86 models wan go check for me it would be nice i kinda think this wire is a fuel injector wire but it comes off the white 10 pin connector and when u plug it into straight pos like i said it starts dumping fuel and shoots black smoke out. i hook it to a ground and notice no change. also it has a really rough miss and doesnt seem to have the power it should have stock. i have changed all wires plugs cap rotor and even fuel injectors. i have even looked at tmoss wiring diagrams trying to fig the problems out. but it seems alsmost all my fuel wires are tan. i need to fix this its driving me crazy
