87'-89' warning indicators
87'GTstang
1,025
Okay i've done a test and out of the 4 indicator lights (on the lower right I/P bezel), only one light bulb works. So, does anyone know what kind/type of bulb is to replace it, I can't seem to find a replacement anywhere
pull one of them, read it, and get the same ones. or just take it with you and eyeball it. i once found out what they were, but cant remember. im sure someone does.
good luck.
I'm talking about the ones that illuminate the low oil, low fuel, low coolant, and low washer fluid lamps. 194's are the main bulbs for the cluster, the warning indicator bulbs are less than half of the size of 194's. Almost every store i've been to has given me the lame push-off by saying "try the ford dealership" :notnice:
