87-93 Which year had forged pistons?
  • Thread starter Thread starter nos90gt
  • Start date Start date Oct 7, 2005
1 of 2 Next Last
N
nos90gt
70
Central FL
Oct 7, 2005
  • Oct 7, 2005
I have a question I hope you guys can help me with. 87-93 Ford 302, Which year had forged pistons? 91-92? Please let me know. Thanks, Scott insane6925@aol.com
88gt
794
Drillers cabin
Oct 7, 2005
  • Oct 7, 2005
87-92 had them....93's were hyper-whatever's...
cjman15
Banned
Apr 15, 2004
1,009
Fairfield, PA
Oct 7, 2005
  • Oct 7, 2005
Correct. ^^
Autobodypro_1
76
Florida
Oct 7, 2005
  • Oct 7, 2005
Actually, '85's had them in a dished version like the '87-92's and '86 had a flat topped version, '93-95 went to hypereutectics(cast)
HISSIN50
34
129
Oct 7, 2005
  • Oct 7, 2005
If purchasing a late '92 model year motor, it would be wise to check - that is when the switch was made.
Good luck.
trents99
438
Hampton, GA
Oct 7, 2005
  • Oct 7, 2005
Good luck.
This is what I've always heard too
troyGT03
278
too close to memphis,tn
Oct 7, 2005
  • Oct 7, 2005
absolutely correct.
Aliate X
602
Rockland NY
Oct 7, 2005
  • Oct 7, 2005
Other parts are going to break on a stock 5.0 bottem end LONG before the pistons just to let everyone know.
gt40_2003wes
I did sound a wee bit gay there.
Aug 14, 2005
461
ky
Oct 7, 2005
  • Oct 7, 2005
pretty sure it was in 92.
super302
I'd do anything for free Bapples
May 29, 2004
2,878
Davenport, IA
Oct 7, 2005
#10
  • Oct 7, 2005
  • #10
92.95 (thats a decimal point)
87'GTstang
1,025
#11
  • Oct 7, 2005
  • #11
All things being equal, any power adder should eat the hypereutectics (yes that's how it is spelled ) long before they will the stout forgings.
ARMAGEDON
100
Oct 7, 2005
#12
  • Oct 7, 2005
  • #12
I ran 150 shot w/ TFS heads, Edelbrock intake and all the other stuff w/ the stock '87block w/ forged pistons for years w/ no problems. Great block and pistons. Oh yes, ditto on the years.
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Oct 7, 2005
#13
  • Oct 7, 2005
  • #13
VERY LATE 92s started the switch, 1 trick I learned a long time ago that is NOT 100% Foolproof, but is pretty accurate is the color of the Oil Pan.
Silver Pan = Forged
Black Pan = Hypers
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Oct 8, 2005
#14
  • Oct 8, 2005
  • #14
Rumor has it that the very late production 92's made the switch to hypers -- if your valve covers still have legible bar-code stickers on them (fat chance), and it's a 92 model with a July or August, 92 build date, chances are good you've got hypers, not forged.
notchback
1,950
St Clair Shores MI
Oct 8, 2005
#15
  • Oct 8, 2005
  • #15
yeah but he's wanting to know how much he can spray....i wouldn't spray more than 100 on hyper's
dkins419
187
Michigan
Oct 8, 2005
#16
  • Oct 8, 2005
  • #16
Silver Pan = Forged
Black Pan = Hypers
I thought it was a a greenish pan = forged ? not sure though.
Euphoric306
905
#17
  • Oct 8, 2005
  • #17
from what im gathering forged are much better than hypers... so why did ford make the switch??? probably to save costs
GroverDill
GoldMember
5,442
1,490
214
Demotte IN 46310
Oct 8, 2005
#18
  • Oct 8, 2005
  • #18
The hypers are fine, just be sure the tune is on point.
433 rwhp on stock hypers. Changing cam and intake looking for more.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Oct 8, 2005
#19
  • Oct 8, 2005
  • #19
Hypers are fine in the right application. They actually stronger than forged -- however, they're not as ductile. So when things go wrong in the chamber -- detonation or lean with nitrous for example -- a forged piston is more forgiving than a hyper. To oversimplify - forged pistons bend - hypers break. Because they're more brittle, when they let go they usually take out a bunch more other stuff. With a forged, you might just push a hole through the piston. With a hyper -- a lot more concomitant damage occurs.
Autobodypro_1
76
Florida
Oct 8, 2005
#20
  • Oct 8, 2005
  • #20
pistons
Forged pistons are better for hipo use,but hypereutectics seal better due to tighter fit. Forged pistons have a lot looser running clearance .004-.006"vs. .001-.002" which means less internal friction but more oil consumption and noise which is why Ford switched. Heavy nitrous, boost and heat makes pistons expand and makes piston ring gaps butt together which scores cylinder walls, which is one of the reasons race cars use them.
1 of 2 Next Last
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
Interior and Upholstery 87-93 Mustang Metal Side Headliner Trim Clips Upper Hatchback Coupe Door OEM 524
  • Noobz347
  • May 25, 2025
Fox 5.0 Mustang Tech May 25, 2025
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
