I have a stock 1987 Ford mustang GT, only mods are under drive pulleys and electric fan. When I start the car in the morning and its cold the idle will go up to 1500rpm for a second and then drop to 1000 and then the idle will surge from 700-1200 until the car warms up, then once the car warms up the car idles high at around 1200 rpm, and if I pull the spout connector it goes down to 1000rpm. My timing is set 10 degrees.
Also I have tried checking TPS I am getting the right voltage, and also I tried disconnecting the IAC with the engine running and the engine shuts off, don't know if that's normal or not because when they recommend to try that they talk of the engine sputtering or smoothing out.
Update - Pulled some codes
ON KOEO got codes 54, 34 and under the stored codes I got 11
With KOER I got 98 then 54
