87 gt missing and backfireing
  • Thread starter Thread starter wakeboarder_909
  • Start date Start date Sep 13, 2005
W
wakeboarder_909
  • Sep 13, 2005
i have an 87 gt that used to run great but late may all of the sudden it started giving me all kinds of fits. 1. when you try to start it up, it starts up then starts missing and running rough then stalls out. 2. untill the motor is warm the car will stutter and miss and backfire and pop 3. even when the motor is warm the motor still seems to have a little hesitation right off of idle and seems like it is slow to come off of the RPM when it is revved. i haved tried all kinds of things and dont know where to go next. maybe electircal? because if your lucky the car will run great only every now and then.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 13, 2005
  • Sep 13, 2005
Dump the codes and see what the computer says is wrong…
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Walmart.
Or for a nicer scanner see http://www.midwayautosupply.com/detailedproductdescription.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $35.
W
wakeboarder_909
  • Sep 13, 2005
i took it to an individual that has the same tester as a dealer and read egr valve, replaced it worked good for a lil while and now the same crap. also replaced distributer, cap and rotors, ignition module and plug and wires
HISSIN50
34
129
Sep 13, 2005
  • Sep 13, 2005
I would use JR's post above to pull the codes again and see what is stuck in the memory. The puter has self-diagnostics to help you to diagnose issues since the systems are complicated.
Good luck.
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
Engine Coolant boiling in hose?
  • Teen'93stang5.0
  • Jun 3, 2026
Fox 5.0 Mustang Tech Jun 8, 2026
Mustang5L5
L
Help with 1986 GT 5 Speed Please
  • Lcasada1999
  • Mar 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
  • brandyn200
  • Jun 20, 2026
AeroCoupe
Help! Fox with idle issues
  • bbarton
  • Sep 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2026
AeroCoupe
