87 GT OVERLOADING WITH FUEL
  • Thread starter Thread starter justinblevins93
  • Start date Start date Jun 27, 2011
J
justinblevins93
  • Jun 27, 2011
ok i have a 87 mustang gt. it was running fine one min and i stopped at a stopsign and it started surging idle. so i drove it to town and was gonna get a tps andwhen i got out at the parts house it was overloading with fuel so bad it was smoking. long story short i have changed the TPS, THROTTLE AIR BYPASS VALVE, EGR VALVE, PVC VALVE, FUEL PRESSURE REGULATOR, INJECTORS AND O-RINGS AND CAPS, AND TEMP. SENSOR, ALSO RAN A COMPRESSION TEST ON EACH CYLINDER AND ALL WERE 90LBS OR ABOVE AND CHECKED THE INTAKE GASKETS AND CHANGED THE PCM AND I DID A VOLTAGE CHECK ON THE INJECTORS, THEY ALL HAVE 12 VOLTS WITH KEY ON AND ENGINE OFF....... The only thing i havent changed is the intake, fuel pump, and map sensor. but after those im drawing a blank. help please.....correction just changed the map sensor and no luck.
97gsr
31
  • Jun 28, 2011
i am in the same boat i tried everything but the map sensor. i chased all the wired back to the comp found one bad ground but mine still runs pig ass rich
Mustang5L5
Mod Dude
Feb 18, 2001
43,390
18,133
224
Massachusetts
Jun 29, 2011
  • Jun 29, 2011
As with any sort of "whats wrong" threads....the typical first answer is....
"have you run the engine codes yet?"
Without those, there is no point in guessing. 87's don't have a check engine light, so no idea of there are any codes stored. You need to run the engine off and engine running codes.
Don't just buy random parts and throw them on the car. Not really cost-effective. If a sensor is bad...the computer will tell you.
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
D
89 foxbody fuel pump not priming
  • Dubsantana
  • Jul 6, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 12, 2025
AeroCoupe
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
