please help, i put a 87 331 stroker in 89 gt roller, i had to use the 87 engine wiring harness, but the fuel pump wont work. the 89 body has an extra plug with 7 wires comin out of it, i beleive this is for the eec relay, can i wire this so fuel pump work? the fuel pump relay has no power on the red wire but the pink is hot. do i have to switch to a 89 wiring harness for this configuration to work?. the 89 had the wiring harness removed so i used the one from the 87. i would like to switch to mass air but want to get it runnin --the eec relay is missing -should it run without it and will it run with it?any help would be greatly appreciated---
