87 Mustang Charging problem
itsafastford
Ohio
My 87 5.0 won't charge the battery. I have replaced the Alt. (several times) and replaced the battery. I have checked the wires going to the battery. I have run an electrical check on the Alt circuit but I can't find a good schematic to tell me what wire should have what? Please help. Thanks.
Check out the lt green/red wire going to the alternator to make sure it has 12 volts when
the ignition switch is in the run postion. It is the alternator sense wire that tells the
alternator to power on when the engine is running.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine/
