The rear control arms are longer on a T-Bird,as are the front a-frames.If you change all of the front suspension,you can use the Stang parts.The motor mounts are also different for the Bird.The H-Pipe and headers are a bolt on.If you have a column shifter,the linkage may need to be moved a bit,and the mid pipes lengthened.The tail pipes from a Stang will also work,but like the mid pipes,also have to be lengthened.The Mustang's 11 inch front brakes are also a good upgrade from the smaller brakes on the Bird.You'll need to swap spindles ,lines,calipers and rotors,and a new master cylinder and proportioning valve as well.These cars have a ton of potential.I've been going through it for years.LOL.
