R redeye4u New Member Apr 25, 2003 10 0 0 wisconsin May 30, 2004 #1 May 30, 2004 #1 this will sound strange. but which fuel line is which. the line with the schrader valve is the return line and the other is the inlet line right. if i have them backwards will the motor still run.
jrichker StangNet's favorite TOOL In Remembrance. Thank you for your contributions Mar 10, 2000 27,512 2,813 234 Dublin GA May 30, 2004 #2 May 30, 2004 #2 They wont fit backwards with the stock fuel rails. The fuel rail couplings are different sizes. The supply rail has the scharader valve in it.
R redeye4u New Member Apr 25, 2003 10 0 0 wisconsin May 30, 2004 #3 May 30, 2004 #3 thank you. changed the lines did not run. will change back agian. but i still have no pressure at the schrader valve with the gauge on.
