88 speed density misfire and bucking
  • Thread starter Thread starter kush
  • Start date Start date May 29, 2026
K
kush
DFW
May 29, 2026
  • May 29, 2026
Hey guys, recently I've been dealing with an intermittent bucking at around 3000rpm that I'm pretty sure is a fuel-related issue. I've also noticed this chirping sound at idle. It's also audible until around 2000rpm. I hear it during acceleration and coasting. On wot and anything above 2000rpm, I can't hear it. At idle, it sounds like it's coming from the #3 or #4 injector. Fuel pressure is good. It's got a new regulator and fuel filter. I have videos of it running, but the files are too large to post here. Thanks!
Admin Dude
Jan 4, 1985
43,353
21,554
234
Box behind Walmart
May 29, 2026
  • May 29, 2026
Electrical Thread 'How To Pull Codes From EEC-IV In 86- 95 5.0 Mustangs'
Jan 27, 2016
@Noobz347 - The code dump procedure isn't in the sticky - you may want to add it...
Dump the codes: Codes may be present even if the Check Engine Light (CEL) isn't on.
Dumping the computer diagnostic codes on 86-95 Mustangs
Revised 26-July-2011. Added need to make sure the clutch is pressed when dumping codes.
Codes may be present even if the check engine light hasn’t come on, so be sure to check for them.
Here's the way to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for...
  • jrichker
Blown88GT
2,283
524
164
Palm Beach Gardens, FL
May 30, 2026
  • May 30, 2026
It's probably the fuel pump. Fuel pressure can be good at idle, but not under load. Attach a fuel pressure gauge to the Schrader valve with a long hose, zip- tie it to the wiper blade so you can see it from the driver's seat, close the hood & go for a rip. You will probably see the gauge drop to 0 for a second & then come back.
Reactions: General karthief
K
kush
DFW
May 30, 2026
  • May 30, 2026
Noobz347 said:
[EMBED content="post-8947967"
Koeo codes 11
Koer 44/94. I ran it three times using an innova obd1 code reader and one of the times it threw a 45. Of those 3 times I ran codes, 1 time it said 4 for number of cylinders, another time 6 and one time it didn't give any reading at all.
All my emissions are deleted and the ports in the back of the heads are blocked with plugs from LMR, so 94/44 are expected.
K
kush
DFW
May 30, 2026
  • May 30, 2026
Fp at idle is steady at around 39psi. Good call on reading it while driving, never thought of that; I'll give that a shot and report back.
I know videos would help a ton. I'll try to get them up on YouTube and post the links here.
K
kush
DFW
May 30, 2026
  • May 30, 2026
View: https://youtube.com/shorts/rIw6ZAETaHg?si=NawPJERnzYeVptLG
K
kush
DFW
May 30, 2026
  • May 30, 2026
View: https://youtu.be/ftnNLJYljhM?feature=shared
2000xp8
SN Certified Technician
Aug 8, 2003
8,056
1,641
194
NJ
Jun 5, 2026
  • Jun 5, 2026
I'm always skeptical about calling a miss a fuel problem.
I've seen bad injectors before, but you could hear the engine tone change at idle.
I've not heard of injectors chirping, to me that sounds like the belt in the video.
I'd remove the belt and run the car and see if it still chirps.
Reactions: DadLife0724 and AeroCoupe
Mindseye007
10 years still blowing strong
5 Year Member
Oct 21, 2020
586
137
63
ontario
Jun 8, 2026
  • Jun 8, 2026
Sounds like tensioner/idler pulley...
DadLife0724
342
238
53
Cooperstown, PA
Jun 8, 2026
#10
  • Jun 8, 2026
  • #10
Get a hose or piece of pipe, put one end to your ear and move the other end around in that engine bay. When you get close to the chirp it will get louder. That should help you pin point it. Or at least get you close.
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
D
Foxbody Misfire 5.0 Swap
  • DPORTER0729
  • May 2, 2025
Fox 5.0 Mustang Tech Jul 13, 2025
90sickfox
A
Rough idle - cylinder 1 and 6 misfire HELP
  • austindavies935
  • Jul 24, 2025
SN95 4.6L Mustang Tech Jul 24, 2025
gkomo
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
