89 Clutch Issues
  • Thread starter Thread starter Mudpuppy
  • Start date Start date Sep 11, 2012
M
Mudpuppy
  • Sep 11, 2012
I have an 89 Mustang 5.0 clone with a 92 5.0 engine. New clutch. New trans. Can't seem to get the clutch adjusted. Seems like there is too much slack in the clutch cable. The plastic adjuster underneath the dash just adjust out releasing the clutch. It won't shift into gear and has no clutch. I believe it needs a new adjuster. Tried spacers underneath the car doesn't help. Anyone have any ideas, suggestions or any other comments about this?
F
Fox8950
247
Sep 11, 2012
  • Sep 11, 2012
The plastic stock quadrant is overly flexible and the teeth that do the self adjusting tend to wear out after a bit so you're probably correct. My suggestion would be an aftermarket aluminum quadrant and a firewall adjuster for the cable.
M
Mudpuppy
  • Sep 12, 2012
Thanks. What about something like this:
http://www.ebay.com/itm/79-04-Ford-...1993457300559999737&pid=100015&prg=1006&rk=1&
Does the flat piece with teeth and 2 holes replace the plastic piece under the dash? And I noticed some kits come with an adjustable cable - do I need to replace the cable as well? Or can I use the cable that is already on there? In researching I noticed that some people said don't use the adjustable cable just use the stock cable and this after market quadrant and a firewall adjuster. Talking to a local Mustang guy he mentioned something about a firewall adjuster.
Jarrod@latemodel
Late Model Restoration
47
39
Tx
Sep 12, 2012
  • Sep 12, 2012
Is your cable stretched out? If your cable is stretched, then go ahead and replace it at the same time. I would for sure pick up a firewall adjuster and new quadrant.
Mustang Clutch Cable, Quadrant & Firewall Adjuster
M
Mudpuppy
  • Sep 12, 2012
No it is a brand new cable along with the brand new clutch. Just not working right and hasn't been.
Checked your link - do you sell just the quadrant and firewall adjuster without the cable?
F
Fox8950
247
Sep 12, 2012
  • Sep 12, 2012
You shouldn't need an adjustable cable with the firewall adjuster, that ebay link would be all you needed but the firewall adjuster in that auction looks like it only has 1 mounting point (I've seend quite a few that have dislodged themselves from the hole in the firewall). Late Model Resto has better quality for sure but if you were strapped for cash the ebay one would work if you don't strip the screw hole out and keep an eye on it.
gearheadboy
1,425
177
84
Greencastle Pa
Sep 12, 2012
  • Sep 12, 2012
I bought an adjustable cable when I did my quadrant. I also added the firewall adjuster. I get it close underneath then fine tune it with the firewall adjuster. I'm pleased.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 13, 2012
  • Sep 13, 2012
Clutch adjustment
Do the clutch adjustment first before considering any other problems. With the stock plastic quadrant and cable, pull up on the clutch pedal until it comes upward toward you. It will make a ratcheting sound as the self adjuster works. To release to tension of the stock quadrant, use a screwdriver to lift the ratchet paw up and out of engagement with the quadrant teeth.
A binding clutch cable will make the clutch very stiff. If the cable is misrouted or has gotten too close to the exhaust, it will definitely bind. The binding common to adjustable cables is often due to misplacement of the adjusting nuts on the fork end of the cable. This will also cause the cable to wear and fray. Both nuts should be on the back side of the fork so that the domed nut faces the fork and the other nut serves as jam or locknut to the domed nut.
Clutch pedal adjustment with aftermarket quadrant and cable: I like to have the clutch completely disengaged and still have about 1.5” travel left before the pedal hits the floor. This means that I have only about 1” of free play at the top before the pedal starts to disengage the clutch. Keep in mind that these figures are all approximate. When properly adjusted, there will not be any slack in the clutch cable. You will have 4-15 lbs preload on the clutch cable.
The quadrant needs to be replaced if you use any type of aftermarket cable or adjuster. My preference is a Ford Racing quadrant, adjustable cable and Steeda firewall adjuster. The adjustable Ford Racing cable is just as good as the stock OEM cable. It allows a greater range of adjustment than a stock cable with a aftermarket quadrant and firewall adjuster. Combined with the Steeda adjuster, it lets you set the initial cable preload and then fine tune the clutch engagement point to your liking without getting under the car.
Using a stock OEM cable, firewall adjuster and a single hook quadrant may result in not having any free pedal travel before the clutch starts to disengage. I found this out the hard way.
See Summit Racing - High Performance Car and Truck Parts l 800-230-3030 for the following parts.
Ford Racing M-7553-B302 - Ford Racing V-8 Mustang Adjustable Clutch Linkage Kits - Overview - SummitRacing.com Cable and quadrant assembly $90
Steeda Autosports 555-7021 - Steeda Autosports Firewall Cable Adjusters - Overview - SummitRacing.com Steeda firewall adjuster. $40
Jarrod@latemodel
47
39
Tx
Sep 13, 2012
  • Sep 13, 2012
We do. You can buy it with or without the cable.
M
Mudpuppy
#10
  • Sep 13, 2012
  • #10
thanks for all the info - will play around with it and see what I can come up with. got the chilton's manual from the library today just for reference. seems pretty straight forward.
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
