89 gauges
  • Thread starter Thread starter bluebeast
  • Start date Start date Jan 15, 2004
bluebeast
215
Mass
Jan 15, 2004
  • Jan 15, 2004
im looking to buy some white face gauges for my mustang. The problem is that i have an 89 but my speedo goes up to 140mph all the gauges i see for 89's only go up to 85mph. And what is the difference between the 87-89 and the 90-93.
thanks
eric
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Jan 15, 2004
  • Jan 15, 2004
You think you've got problems.....I'm from Canada. Try finding white gauge faces that read in KM/H!!!
Anyway, the difference between the gauges after ‘89 is a result of Ford using a driver’s side airbag in place of the non-airbag column. The column is wider to accommodate the larger wheel centre and as such the gauge layout was changed to fit.
sleeper89
388
Toronto, Ontario
Jan 15, 2004
  • Jan 15, 2004
...also, everyone says 89 has 85mph speedo and 90 has 140mph speedo. my 89 has a 180km/h speedo (~110mph). must be a canadian thing
-steve
Gearbanger 101
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Jan 15, 2004
  • Jan 15, 2004
Yeah, I never did get that? Well screw it, I think I'm going to attempt to make my own and market them. I can see it now....Canadians everywhere will be flocking to my doorstep to buy Metric white gauge faces.:canflag:....well, a guy can dream can't he?
sleeper89
388
Toronto, Ontario
Jan 15, 2004
  • Jan 15, 2004
bluebeast
215
Mass
Jan 15, 2004
  • Jan 15, 2004
so am i out of luck trying to find gauges for my car?
sleeper89
388
Toronto, Ontario
Jan 15, 2004
  • Jan 15, 2004
sorry blubeast, i got a little side-tracked and didn't answer your original post. i've never heard of 89's with the 140mph speedo - but, like i said mine is 110mph - so i'm not too sure. if i had to take a guess i'd say ford probably made this a running change in late 89 model year so the last of the 89's got the 140mph speedo. if that is the case then you should be able to use the white face 140mph for 90-up. otherwise i really wouldn't know.
ttt
-steve
bluebeast
215
Mass
Jan 15, 2004
  • Jan 15, 2004
do the 1990 mustangs have air bags. if they dont will they fit. does anyone know for sure if they fit.
pairofnines
80
  • Jan 15, 2004
My 89 has 140mph speedo, it was a running upgrade in 1989, when they ran out of 85mph speedos. I'm not sure if the 1990 will fit because of the air bag, usually they don't have white gauges for 1989 with a 140mph speedo, just 85mph.
FiveOhhStang
299
Sanger, Cali.
Jan 15, 2004
#10
  • Jan 15, 2004
  • #10
TO ANSWER YOUR QUESTION. YES! They do make White face Guages for 89's....The 89's with 85mi Speedo's where the first half of 89, then the "25th Anniversary" Stangs kicked in with the 140mi Speedo ( 64 1/2 first stang, 89 1/2 25th anni...you get it), Look on ebay, I know Mac Carries them...ummm Bkk Speedware has them...like I said look on ebay, or in your summitracing.com magazine.
-Nick
I
ilovestangsalot
#11
  • Jan 15, 2004
  • #11
i have an 89 gt 25th anv. it doesnt have a 140 it has a 85.!! I bought the 140 white face gauage and put them on and i thought i could just change the gear.!! well u can get a 23 thooth gear and it will be right but u have to have a 8 tooth internal gear so i had to spend 50 bucks and buy a new guage pod w the 85 back on it. to fix it all cause it became to much of a hassle. it isnt worth it plus it is cool to wrap the 85 all the way around and freak ur friends out :}
schoonover_88
189
#12
  • Jan 15, 2004
  • #12
Try stangparts.com . I have seen 1989 140 MPH speedos there before.
fivelitercoupe
132
Longwood, Florida
Jan 15, 2004
#13
  • Jan 15, 2004
  • #13
I have an 89 coupe with a 140 mph speedo and I put white face gauges in it. I see them all the time for the 140 mph speedo in an 89 version, MAC, BBK, and other major companies make them. Flip threw some major catalogs and u'll see um
HISSIN50
34
129
Jan 16, 2004
#14
  • Jan 16, 2004
  • #14
i would also try calling the manufacturer/vendor and see if they will just piece it together for you. i had similar headaches for my gauges. they eventually sent me the right speedo.
you can get speedo recalibrated from Brothers Performance or some subsidiary of them. search in here for more info if you want. i remember the threads from about 6 months ago).
good luck.
bluebeast
215
Mass
Jan 16, 2004
#15
  • Jan 16, 2004
  • #15
thanks i found some from mac that i think i am going to get.
C
cmclean
243
Houston, TX
Jan 16, 2004
#16
  • Jan 16, 2004
  • #16
I had a '89 coupe with 140 mph gauages, and it had the 25th anniversary badge on the dash. I think it just depends on luck of the draw.
327_89gt
Utah
Jan 16, 2004
#17
  • Jan 16, 2004
  • #17
Before you purchase the Mac gauges check these sites out. I personally have the NR el-glo gauges and they're sweet. A little pricey compared to others but the quality is top notch. Hopefully this helps.
http://florida50.com/
http://www.nrauto.com/
http://secure.50resto.com/category.cfm?SID=1&Category_ID=536
http://store.summitracing.com/default.asp?target=/main.asp&ms=64
http://www.mustangsunlimited.com/aspfiles/default_frame.asp?UID=2003091619091758
Fox Rear Seat Belts - 87-89 vs 90-93 length
  • dan50
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
Mustang5L5
WTB Oxford white hood, bumper and fender for LX foxbody
  • keel
  • Jan 7, 2026
  • Want to Buy
Want to Buy Jan 7, 2026
keel
P
Electrical 1988 GT Wrong Cluster- causing electrical issues?
  • pindude80
  • May 6, 2025
Fox 5.0 Mustang Tech May 6, 2025
pindude80
P
  • dan50
  • Jul 18, 2026
dan50
89 LX Electrical Troubles
  • fun331
  • Oct 25, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 27, 2025
fun331
