posting this up just to see whats out there for trade.looking for fast street cars,03-04 cobras,supras, Vetts, etc..or other drag cars( if street-ish legal), cars been 9.70@137mph all motor.Will go faster, have slips and video, paint is great, cage and all jams been repainted same color as outside of car.car has head lights,brake lights, blinkers, can have wipers put back on, car is taged,registerd and ispected i drive it on the street when its nice out on the weekends.
88' mustang hatch, fully built chassis,rearaluminum fire wall,fire supression system,8.50 10 point cage with rear cross bar.kirkey seats,carepet,stock dash,full autometer gauges with play back tac, welded in upper and lower battle boxes, weld in subframe connectors, upr upper and lowers, QA1 adj. rear shocks, AeroSpace front and rear brakes,braided steel brake lines, and front billet hubs, Team Z k member and front control arms, QA1 front adj coil overs,UPR alum. camber caster plates,Cobra front and rear bumper and side skirts, Racecrafters 18" rear wing, and rear chute, Holeshot holestar 3 piece wheels with stainless bolt upgrade, with Hoosier 275/60/15 Drag radials and brand new DS2 front tires.long studs front and rear,Firbottle fire supression for engine and cabin.
700hp all motor..418" Dart iron eagle block, AFR cnc 225 renegade heads, eagle armor 4340 crank,eagle H beams with L19 arp bolts,Diamond gas ported pistons (12.5.1) can crusie on pump gas,hell fire rings, coated bearings,comp solid roller 271/280, .741/.745 lift on a 107lsa.,comp lifters,hardend push rods,scorpion 1.7 stud mount rockers,adj. oil pump, msd billet dizzy,taylor spiro pro 9.mm wires,Super vic intake,Aerospace water pump and vacum pump,griffen rad,120amp 16v alt, 16v XS power battery, AccuFab 4150 throttle body, presicion 60lb injectors, aeromotive fuel rails,A1000 pump,and reg,16gal fuel cell,10a feed.. Hooker super comp 2" long tubes,4" collectors, 4" race bullet mufflers... (motor was just tworn down and gone through this may no nitrous since rebuild)
there is a NX gemini pro power plate kitjust installed on the car but i have not sprayed it yet,though its all hooked up and ready to go. all you need is a bottle..Car will go 8's on a 250 shot.
BigStuff 3 EFI setup,Full data logging with auto correction and live Wideband o2.,MSD digital 6 ignition with jacobs coil. MSD crank trigger, and billet dizzy
Fully built 1.76 Powerglide, pro tree trans brake,SFI front bell,scatter sheild,big aluminum pan,machine billet front drum for extra clutches, billet servo,turbo input, cryo output. trannys rated for 1500hp
SFI flex plate arp bolts and ptc billet sprag converter, chromoly drive shaft and saftey loop, 4130 u joints, billet yolk
8.8 welded tubes,braced,aluminum rear girdle,strange 33 spline axles,strange full spool,cnc aluminum 9" big bearing ends, wolf anti roll bar,
have lots and lots of paperwork on car, plus a book with every manual for the bs3,ignition,switch panels,crank trigger,suspension setups,data logs, plug reading and tune notes, tire psi tests, and so on.
so again, theres alot moreparts to the car, just putting up a feeler to see whats up for trade, dont offer me no bull
junk rat boxes, i wont reply..410-218-1620 txt only. or email. would consider selling for cash but mostly looking to trade.
http://img100.imageshack.us/img100/2756/069bw.jpg
http://img9.imageshack.us/img9/1739/078pf.jpg
http://img33.imageshack.us/img33/9513/012gvhs.jpg
http://img854.imageshack.us/img854/5858/841l.jpg
http://img4.imageshack.us/img4/3108/013nlu.jpg
![Poo dance :poo: :poo:](/smilies/poodance.gif)
